Old 06-05-2013, 11:52 PM   #1
Silver Streak
Silver Streak's Avatar
Drives: 2010 Yaris sedan silver
Light weight wheels
Hey all, I was wondering if you knew of any wheels that are lighter than the tstock ones. Looks are not important to me, as I would probably use my oem covers as well.
Silver Streak is offline   Reply With Quote
Old 06-06-2013, 01:58 AM   #2
YarisSedan
Drives: 08 Yaris Sedan
Konig heliums are great lightweight wheels for the cost
Old 06-06-2013, 02:18 AM   #3
13's (not sure if these will clear the brakes)
Civic VX wheels
14's
Civic HX wheels
Mazda Miata BBS wheels
Enkei RPF1
15's
Konig Helium
Konig Feather
Rota Slipstream
Rota Circuit 8
Mazda Miata BBS
949 6UL (tie for best choice between looks, width, and weight)
Enkei RPF1 (tie for best choice between looks, width, and weight)
I'm leaving out the more expensive rims from Volk/Rays, Joustmeister, Regamaster, etc.
Old 06-06-2013, 02:24 AM   #4
The RPF1's are lighter than the 6UL but cost almost twice as much.
You can see a huge list of wheel weights here: http://www.scribd.com/doc/24224938/Rim-Weight
Old 06-06-2013, 07:43 AM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I'm not sure I understand your request: you want lighter wheels that can re-use the stock hubcaps? That rules out pretty much everything, since alloy wheels can't use hubcaps, but another 15" steel wheel is likely to weight just as much...
Old 06-06-2013, 08:29 AM   #6
Foot
Drives: 2010 3dr yaris
I know that the Heliums will not be available for another few monts from the manufacter. I just purchased some Feathers which I like. I did not get the RPF1s , less than 10lbs, cause I would had to use a 7in width tire and they are twice as much. Stock are 16lbs. Heliums and Feathers are about 12lbs. RPF1s are less than 10lbs.
Foot is offline   Reply With Quote
Old 06-06-2013, 08:53 AM   #7
Silver Streak
Thank you all for your answers. Crankyoldman, my thinking was to make it look as close to stock as possible that's why I said I wanted to keep the wheel covers. I was hoping maybe there were steelies that were light.
Old 06-06-2013, 09:22 AM   #8
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Why not just stick with the stock wheel then? The stock wheels aren't TOO heavy, and you're planning on re-using the stock covers for them.
If you want a lighter alloy wheel, you probably won't be able to re-use the stock wheel covers.
I currently have SSR type F wheels in a 16x7 size +42 offset, they weigh about 11lbs each, but they're a little on the pricey side.
Black_griffin6 is offline   Reply With Quote
Old 06-06-2013, 12:13 PM   #9
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
you can get some lightweight wheels and zip tie your hubcaps on... just a suggestion
-Derrick-
Old 06-06-2013, 05:29 PM   #10
There aren't. Because steel.
I won't say impossible, but I've never seen it done on a Yaris.
Old 06-06-2013, 05:31 PM   #11
Enkei RPF1
win.
Old 06-06-2013, 05:32 PM   #12
6UL 15x7 $129
Enkei RPF1 15x7 less than $200
Old 06-06-2013, 09:48 PM   #13
justjesus
justjesus's Avatar
Drives: 2008 Liftback
he meant they cost 55% more ?
Old 06-06-2013, 09:50 PM   #14
justjesus
justjesus's Avatar
I knew a guy who had the HX wheels, but wanted to keep a low profile on his '89 Si Civic. He did just that. Zip tied OEM wheel covers to the lighter HX wheels.
He went as far as removing his sun-roof equipped roof and swapped in a solid roof from a DX model (base model)
Old 06-06-2013, 09:57 PM   #15
screenprintr
screenprintr's Avatar
Drives: 2010 Toyota Yaris
Don't understand why. Aren't the Yaris' light enough? Any lighter and they'll blow away in the wind while standing still.
screenprintr is offline   Reply With Quote
Old 06-06-2013, 10:47 PM   #16
Yup, that's what I meant.
6UL 15x7 $129
I just did a quick google search, didn't see the RPF1's go for under 200. Then again, didn't spend any time looking.
Old 06-06-2013, 10:50 PM   #17
Essentially makes the engine work more efficiently by having to work less to rotate lighter wheels (frees up some existing hp to the wheels), so better acceleration. Also enables you to stop sooner and corner better. Oh, and better mpg.
Old 06-07-2013, 05:58 PM   #18
seth_man
seth_man's Avatar
Drives: 08 Liftback
http://www.good-win-racing.com/Mazda...t/21-1050.html
15x7 rpf-1 for 189
seth_man is offline   Reply With Quote
Stock 15 inch rs wheels, weight? viggen Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-20-2012 10:26 AM
looking for cheap, light, white wheels yarswiss Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 07-24-2010 02:37 AM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 05:43 PM
12/20/08 Buddy Club USA 5th Anniversary Clearance SALE DuckinOut California 3 12-18-2008 01:25 AM
