Old 06-17-2013, 12:35 AM   #19
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
People always question my tire wear at my pressures. The way I drive...I use the whole tire. My tire wear is generally better then normal with the edges still barely wearing out first. I used to run the goodyear fuelmax tires in my old xb at 63psi...that was required to break even from the 2-3mpg loss I got by switching to those pieces of shit.
For most people...I would not crank the pressures up to quite the levels i run. Unless you have performance driving/ racing experience. Traction in the rain is obviously reduced. Id say mid 40s is the best bang for buck for decent gains while still being safe.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 06-17-2013, 11:33 AM   #20
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
Best tank yet. I calculated 51 mpg. I had around 470 miles on the tank, sitting on E. I forget how much fuel it took to fill up, but I used the calculator on my phone while sitting at the pump. The car's FE gauge indicated 52, pretty close. My Scangauge was also pretty close, but I don't remember the exact number. I did have to enter a correction to the amount of fuel when I did the "Fill Up" on the Scangauge.
I got my first oil change at the dealer. I requested synthetic, but the tech never got the instructions. Oh, well. They say they did put 38 psi in my tires as I requested, but I know I need to verify that....
Amdkt7 is offline   Reply With Quote
Old 06-18-2013, 04:57 PM   #21
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
It takes maybe 25 minutes to change the oil in the Yaris, by far the easiest car I've ever done an oil change on. I started changing mine on my own again after the dealership went to that stupid appointment only junk.
Old 06-18-2013, 05:47 PM   #22
Amdkt7
Returning to Toyota
Years ago I found that I would never get around to oil changes if I did it myself.
So I will probably continue to take it to the dealer, but I'm beginning to think that the free service is not worth the hassle. I did get to eat some pretty good food while I waited.....
Also, since I live in an apartment and dealing with an oily mess is a huge hassle, let alone against the apartment rules it is best that I take the car somewhere to have it done.
Old 06-18-2013, 06:40 PM   #23
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
I can't seem to break the 30MPG barrier.. heh
Old 07-02-2013, 12:22 PM   #24
Amdkt7
Returning to Toyota
Did it again yesterday. 55 going to work, and 60.7 going home. I'm still trying different techniques, but the very best trick is to stick in the clutch and coast as much as possible.
I have found that it does not seem to hurt to stay in the lower gears longer to get up to speed. Sometimes waiting until 4k RPM to shift, trying to hold the throttle between 30 to 40 TPS (around 1/3 throttle). Much more fun that way, the car accelerates much faster. As soon as I reach my target speed I am either going to top gear, or back to coasting.
I still coast with the engine on, and one or two traffic lights I will shut off the engine while I am stopped.
Old 07-05-2013, 09:10 PM   #25
nookandcrannycar
Well.... I'm having trouble breaking 38.
Do you know if this is similar to other Yari in your area? I know when I've used multiple tanks driving at lake level at Lake Tahoe (a bit over 6,000 ft elev.) that my MPG dropped a few MPG from a normal tank here (virtually at sea level).
Old 07-05-2013, 09:18 PM   #26
nookandcrannycar
Originally Posted by malibuguy View Post
Running only 38psi in your tires is childs play. I run 54psi.
Doesn't it feel as though you are driving on bricks?
And 63 PSI on your old tires!
Old 08-20-2013, 02:24 PM   #27
Circa
Drives: Toyota Yaris 1.2
60MPG would be a dream lol!
car service
Circa is offline   Reply With Quote
Old 08-20-2013, 03:01 PM   #28
Amdkt7
Returning to Toyota
It's pretty hard to do, but my route to work seems to be ideal. I have not been able to do it for a while now, my new girl friend seems to have broken my concentration!
Old 10-26-2013, 01:43 AM   #29
Nigel8600
Drives: 2008 Yaris Sedan
Originally Posted by Amdkt7 View Post
I put 38 psi in 5000 miles ago. I use pulse and glide, which is all about coasting! This route that I take to and from work is perfect for doing a lot of coasting.
The ride home has a net 300 foot elevation drop, which is why my drive to work is not quite so good. Last few days I managed above 50 mpg going to work,
A few weeks ago I was getting 47 going to work and 51 coming home, but I added the pulse and glide technique after trying it in rush hour traffic crossing the city on the interstate and still getting 50 mpg. Made a believer out of me!
Thanks for the vote of confidence! Some people are born to bash I guess.
this thread is veeerrrryyyy interesting. I am always looking to increase my fuel economy since I am a courier in the city and fuel is my big expense. This is the first I am hearing about increasing tire pressure, maybe I will go from 32 up to 40 for now. My motto I live by in my manual cars is "If my foots not on the accelerator then I am in neutral." It seems to work well for me.
Nigel8600 is offline   Reply With Quote
Old 10-26-2013, 01:55 AM   #30
Nigel8600
My 06 civic is awesome changing oil in now too so I always do them myself. I used to change my oil on an 05 civic and what a pain it was to get to the filter in that 1.7L but the 2006 1.8L is right in the same spot as our 1.5 yaris. If you guys want to change oil even easier order a Fumoto F103 or F103N valve for the yaris. I did last night. :)
Old 10-29-2013, 03:09 AM   #31
nookandcrannycar
Old 10-29-2013, 07:46 AM   #32
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
I'm planning a 2*200km trip this weekend, highway only.
Anyone willing to place a bet?
On a similar track (but not a highway) I reached 66, however it was also too curvy to go faster than 55MPH.
This time I'm not sure how fast I want to go (remember - no speed limit here on a lot of roads, as long as the two directions are separated physically), I guess 56 ;)
dj92 is offline   Reply With Quote
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 09:38 PM
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 01:15 PM
Delighted to break the 50 MPG barrier! STC Fuel Economy Forum 35 06-26-2010 01:02 PM
Break in period MPG Nuttyguy Fuel Economy Forum 19 03-08-2010 06:50 AM
What kind of break in mpg did you get? AdeJong 03 Fuel Economy Forum 31 02-16-2009 06:11 PM
