Old 05-21-2013, 04:00 PM   #1
Septembersrain
♣♀Yaris'ing♀♣
Septembersrain's Avatar
Drives: 2013 Yaris 3-Door LE ~Pearl~
Custom colored rims?
The color on my Yaris is pretty unique so I'm having a hard time seeing any rims I like with it.
Is it possible to have ones custom colored?
Don't be a drip. ◄~(¬ _¬)~
Septembersrain is offline   Reply With Quote
Old 05-21-2013, 04:10 PM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Yes this would be called powder coating almost anything metal can be powder coated
Old 05-21-2013, 04:19 PM   #3
Septembersrain
♣♀Yaris'ing♀♣
I apologize, I'm really new to this so forgive the question bombarding.
How would I go about doing this?
Pick the rim I like, then get it powder coated?
Where do you buy the powder, From the dealership?
Is it hard to do yourself? Is there anywhere that does it?
Thank you for your quick response!
Old 05-21-2013, 04:24 PM   #4
1.5
Form>Function
1.5's Avatar
Yes you can buy a wheel and then take it to a powder coater and they will source out the powder from their distributor and will have everything you need. Typically it costs around 50-100 per wheel.
Without a powder coating machine, oven, and experience you would not be able to do it yourself.
If you google powder coat and your zip code you should find something.
There are hundreds of thousands of color options.
Old 05-21-2013, 09:49 PM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
^what he said.. Or just buy them already painted like my lazy ass
-Derrick-
Old 05-21-2013, 10:52 PM   #6
Or, clean, prep and primer, paint and clear coat them yourself. If you prep them properly and use good quality primer and paint they will look good for years.
Old 05-22-2013, 03:41 AM   #7
7:34pm
Drives: 07 Yaris
Powder coated wheels are very nice. A bit more pricey than spraying them yourself but they will have a more durable and cleaner finish.
PS. If you do powder coat wheels, just be cautious of the composite of the wheel. Some wheels have a negative side effect from it.
7:34pm is offline   Reply With Quote
Old 05-22-2013, 01:56 PM   #8
Wheels, since they are usually pretty dirty, must be prepped REALLY well for powdercoating. If they are already painted or powdercoated, they will also need to be stripped first.
A good powdercoater will take care of all of those things without a problem.
Part of the cost posted earlier (sounds about right for my area as well) is the stripping and that they have to deal properly with the hazardous waste (lots of it). I'm happy to pay for that.
Old 06-25-2013, 01:40 AM   #9
Billhenry
Expert
Billhenry's Avatar
Drives: Toyota Yaris
I will suggest you not to do by yourself if you really need to just bring the rims to dealer and do the powder coated with your selected color. Alloy rim usually coated with steel color so its your choice to coated again.
car service Brisbane
Billhenry is offline   Reply With Quote
Old 07-01-2013, 09:53 AM   #10
33OH
Drives: '08 Yaris
Just a thought, try looking into the Sparco Assetto Gara's, come in many unusual colors and are relatively inexpensive. Maybe Garm could hook you up with a set, if he carries them.
Old 07-01-2013, 10:19 AM   #11
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
There's always Plasti Dip if you want something less expensive, and less permanent.
https://www.dipyourcar.com/home.php
goliath1812 is offline   Reply With Quote
Old 07-01-2013, 10:23 AM   #12
1.5
Form>Function
1.5's Avatar
Ive used that and had great experience with it, its just harder to keep clean, it's rubber and very porous and scrubbing too hard can cause it to peel off and you would have to respray it
Old 07-01-2013, 12:49 PM   #13
Thanks 330H - we can definitely get SPARCO wheels.
[WTS] Brand New Sport Rims 1151127 Items for Sale by private party 20 03-22-2013 12:28 AM
My 17" alloy rims and Kumho tires... will swap for your original wheels! AutoWashCars NY / NJ/ CT / PA 5 02-08-2011 08:38 PM
Custom tags and custom vinyl ellenbetty Cosmetic Modifications (Exterior/Interior) 9 09-11-2009 04:13 PM
