Old 07-08-2013, 09:36 AM   #1
CMKfromOZ
Drives: Yaris Hatch 2009
Help to fix shaky/loose Dashboard Display
Hi, I am new to the forum. I am in Australia and have a 2009 Yaris Hatch. About a month ago, the internal dashboard display panel started shaking when I go over any bump or slightly uneven section of the road. It is quite noticeable now. I had the car in for a regular service last week and the authorised Toyota dealership where I get it serviced said it would cost about A$850 (about US$790) to repair. This seems crazy, because everything works fine (EG clock, speedo, petrol gauge display etc), it just seems like there are a couple of screws or brackets/clamps broken. Can anyone provide advice about how to get into the "dashboard display" section so I can see if I can repair it myself?
CMKfromOZ is offline   Reply With Quote
Old 07-08-2013, 10:04 AM   #2
It's really easy!
First, pull the two long side pieces from the bottom to remove them. Unhook the emergency lights switch
Next, pull forward the tray/dashboard bezel piece forward, it's a bit stiff but will come right off. then you can have complete access to the actual digital display... Not sure if you can fix what's broken, but with the judicious application of some foam tape you can probably stop the rattling..
Old 07-08-2013, 06:52 PM   #3
CMKfromOZ
Thanks for your reply. Can you point me in the direction of some pictures that explain what you suggest I do? Or at least identify the following bits:
  • the two long side pieces
  • emergency lights switch
  • tray/dashboard bezel piece forward
thanks again
CMK
Old 07-09-2013, 02:42 AM   #4
even better, straight from Toyota:
https://dl.dropboxusercontent.com/u/...nt%20Panel.pdf
Page 16 onward :)
Old 07-09-2013, 05:11 PM   #5
esse10
Drives: 2009 yaris 2 door
COOL
THANKS FOR POSTING THAT PDF FILE We could all use that in the future.
Old 07-10-2013, 07:52 PM   #6
CMKfromOZ
Wow, thanks eTiMaGo. I really appreciate you providing that document.
Hopefully I will have time to try to do the repair this weekend.
regards
CMK
Old 08-23-2017, 03:38 PM   #7
SamMechatron
Drives: 2008 Toyota Yaris Hatchback
Same issue
Hi. The link above doesn't have the file anymore and i need it. Can one of you upload it or give me the link to it please. Thanks
SamMechatron is offline   Reply With Quote
Old 08-23-2017, 03:41 PM   #8
SamMechatron
Page 16 onward :)
Hi. Can you please send me this file? Thanks
Dashboard display and transponder AlanSilberlight General Yaris / Vitz Discussion 0 04-13-2012 07:24 PM
