So i decided to place in the bulb and socket in the side marker (city lights/park light) but it doesn't light up the entire strip which i know it should. Is it because the bulb may be too short or what?
やりすぎだ~
It should only light the bulb which it shows in the picture.
It doesn't light the entire orange reflector. |
even if it isnt suppose to light up the whole reflector, im sure it is suppose to cover a lil more. Like this for example
やりすぎだ~
Did you replace it with another (regular) filament bulb or did you replace it with an LED replacement?
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
i put in LEDs. So thats the issue? guess i should replace it with the normal bulb then
やりすぎだ~
The LEDs you installed will not be as bright as your filament bulb.
Reinstall you original bulb to get that brightness you wanted. |
| Tags |
| bulb, headlight, leds, light, parking light |
| JDM Vitz RS Side Mirror with LED Signal Light | AlainMikli | Cosmetic Modifications (Exterior/Interior) | 35 | 11-18-2013 08:47 AM |
| Yaris 2007 ABS & Brake light issue after wheel bearing change | DevilzMafia | DIY / Maintenance / Service | 4 | 01-17-2013 09:24 PM |
| HELP: New passenger side rear light rubber seal needed | kavos wildcat | DIY / Maintenance / Service | 5 | 12-16-2012 05:38 PM |
| LED Fog light blinking issue | BruceLee | DIY / Maintenance / Service | 20 | 12-01-2012 09:41 PM |
| Original tail light without rear fog light for Yaris 3dr 2009-2011 | Ot_tO | Cosmetic Modifications (Exterior/Interior) | 9 | 08-07-2012 04:27 PM |
