Old 08-05-2013, 07:56 PM   #1
htschek
Drives: 2007 Yaris Sedan
FRONT ABS
Hi All,
The help I received thus far lurking has been much appreciated.
I bought a 2007 Yaris Sedan. Got a good deal knowing it needed some TLC including ABS fixes. First thing I did after reading here thoroughly was pull back wheels, carefully remove harnesses from ABS sensors and they were all full of crap and corroded with green crap. So I replaced the harnesses and the sensors/hubs.
I jumped pins 4 and 13 on the OBDII port and along with codes for the rear wheel sensors, there are codes 33 and 34 which I believe correspond to the fronts as well.
I haven't seen much here on the fronts so can anyone fill me in on the likely issue or point me to a thread I might have missed.
(By the way, I live in VT so leaving the ABS go isn't an option. If the car has ABS, it has to work to pass inspection.)
Thanks for the help already.
Henry
htschek is offline   Reply With Quote
Old 08-05-2013, 09:14 PM   #2
33 and 34 are both rears. 31 and 32 would be the fronts.
where to get front bumper and front bumper support n.a. Canada 5 01-31-2012 01:33 AM
What do you think? painting the front of a Yaris hb front bumper black like the GTI Rnankoo Cosmetic Modifications (Exterior/Interior) 15 08-23-2009 05:49 AM
