Old 08-06-2013, 10:36 AM   #1
anka1976pa
Drives: yaris MK1
how can i remove passengers airbag cover???
hi there I own a 2002 yaris mk1 and I want to remove passenger airbag cover as I'm getting a disturbing rattle from there.Can anyone help with photos please????
anka1976pa is offline   Reply With Quote
Old 08-06-2013, 11:45 AM   #2
According to the service manual it does not separate from the dash, so you would have to remove the entire dash top to get to it. You can get a good look from underneath by removing the glove box and looking up into there.
Old 08-06-2013, 12:38 PM   #3
anka1976pa
Drives: yaris MK1
I have remove the dash but it stuck there and the air bag cover wont let me take out the entire dash...Is there a screw that is holding it from there??? Service manual...where can i see that??? The glove box doesn't help,as the rattle seems to locate below passenger air bag and under the dash...
Old 08-06-2013, 02:18 PM   #4
You have to disconnect the airbag connector and remove the bolt that holds the passenger airbag to the frame in order to remove the dash. The airbag stays attached to the dash.
Old 08-06-2013, 02:43 PM   #5
anka1976pa
Drives: yaris MK1
thank you for your quick reply...much apreciated...
can you upload a photo????I unpluged the airbag but where is that bolt located???
Old 08-06-2013, 03:14 PM   #6
I don't own a first gen, so the only image I have is from the manual:
Old 08-07-2013, 11:21 AM   #7
anka1976pa
Drives: yaris MK1
thank you very very much for your photos and replies ,it seems to me piece of cake after your help...much appreciated.
Fuel filter replacement jaimico DIY / Maintenance / Service 43 03-07-2023 12:05 PM
Car shuts off when A/C turned on... Howster DIY / Maintenance / Service 33 07-06-2013 06:00 PM
How do u remove the automatic shift cover to get to bulb ? Yarisrus DIY / Maintenance / Service 1 04-05-2013 03:22 PM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 04:30 PM
