Old 08-07-2013, 03:37 PM   #37
3cyltrbo
Based on Jason's expertise, I would do the thermostat first. As a quick and dirty test today, drive it and see if the green coolant light goes off. If it stays on and green, then you are in "cold start" mode. If it goes out, then the thermostat is likely not the issue.
Green coolant light???
um????
I think I have a blue???? light when the engine is cold, but it goes out almost instantly in the summer, and only stays on briefly in the fall and spring.
I actually know the exact water temps because I've been driving around staring at my Scan Guage. ............................???
3cyltrbo is offline   Reply With Quote
Old 08-07-2013, 03:40 PM   #38
um????
OK. On the Canadian clusters it must be different. On the US ones we have a little green indicator. Mine takes about 1/2 mile from my house to go out.
What are you seeing for temps? Normally the Yaris will sit in the low to mid 180's F when cruising.
Old 08-07-2013, 03:44 PM   #39
3cyltrbo
Why not?
Dunno, ..............It was crazy. None of the 5 ARP studs would fit into the two outer holes, they refused to thread into the holes.
At first I thought it was maybe just one bad ARP stud / or one of the outer holes was cross threaded?????
NOPE
-None of the 5 ARP studs would thread into either of the outer holes, but they all would easily thread into the 3 inner holes
-All of the OEM hardware (studs or bolts) easily threads into the outer holes (as well as the 3 inner holes)
So.........................right now I have 3 ARP head studs in the inner locations (where the bolts were) .............and the factory OEM studs in the outer locations (but with the ARP nuts) and then of course, 2 unused very expensive ARP studs in a bag in my tool box.
Old 08-07-2013, 03:45 PM   #40
3cyltrbo
I'll take my toy (The Yaris) for a drive tonight and pay attention to both the color of the light (when the car starts) and the water temp (in deg F)
Will
Old 08-07-2013, 03:51 PM   #41
Will
For my car on the freeway, my coolant runs between 179-184*. City driving goes from 180-190's. Parking lot goes up to 202, or around there where the fan kicks in. lol
Old 08-09-2013, 10:03 PM   #42
Viperoni
Drives: 2005 Toyota Echo
It's blue on my Canadian Echo, takes a minute or two to turn off in the summer time. Never saw it turn red, even at lower speed road courses.
2006 Saturn Ion Redline
Old 08-12-2013, 01:27 AM   #43
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Hey Will,
Has anything changed with the stock temprature thermostat?
Greg
Old 08-12-2013, 11:28 AM   #44
3cyltrbo
Originally Posted by tooter View Post
Hey Will,
Greg
Haven't swapped it yet.
Just picked up extra coolant on Friday night (some is always lost when changing a T Stat) and then was busy with other crap all weekend.
I'm booked the next few nights after work, so the first free opportunity is probably Friday night (to swap back to stock T Stat and then after that maybe also try the stock TB)
W
Old 08-12-2013, 11:34 AM   #45
3cyltrbo
You were RIGHT (sorry my bad) the light IS GREEN, but at this time of year it is almost never ever on when I first start the car (even after its been sitting for days which is usually the case)
I drove it briefly yesterday and I was seeing temps in the 140 - 175 range when cruising (outside temperature was approx 91)
Old 08-12-2013, 02:15 PM   #46
tooter
play every day
tooter's Avatar
Those temps are in engine warm up territory so the ECU will still be supplying a rich fuel mix. I'm not certain, but there's a chance that the timing parameters during the warm up cycle might also be different.
Be sure to let me know what happens, because if you're not satisfied, you get your money back.
Greg
Old 08-12-2013, 02:53 PM   #47
Greg
167F to 212F is considered normal (post warm-up) operating temperature to the ECM. Below that is the "cold start mode"
Once the engine gets past the cold start range, the coolant temperature is still used for camshaft timing control:
"Camshaft timing control is performed according to engine operating conditions such as the intake air volume, throttle valve position and engine coolant temperature."
So, I still think that Jason's take on the performance thermostat being the culprit has merit.
Old 08-12-2013, 03:50 PM   #48
At 175, I can't imagine it's in cold start mode. Is the OP losing power at that full temp reading?
Old 08-12-2013, 03:54 PM   #49
175 is over the cold start mode, but he said cruising that he was seeing 140 to 175. If in motion it stays down to the 140 mode, it will run more like the cold mode.
Old 08-13-2013, 04:16 PM   #50
3cyltrbo
If I have the time tonight I'll take it out for a drive and try to get some #'s
At this point its looking like the soonest I can swap the T-Stat is Friday night or Saturday afternoon.
Will
Old 08-13-2013, 04:27 PM   #51
It's ok. We'll wait. We gave Astroman over eight months. You're good.
Old 08-13-2013, 05:19 PM   #52
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
awe, why you got to bring that up
Old 08-14-2013, 12:38 AM   #53
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
x2
Old 08-14-2013, 12:23 PM   #54
3cyltrbo
LOLZ
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Yaris In Forza 3 whooppee777 Off-topic / Other Cars / Everything else Discussions 61 04-03-2010 04:36 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
