Old 08-14-2013, 12:19 AM   #1369
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
No updates yet I guess...
Old 08-14-2013, 02:42 AM   #1370
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Sorry, Blue.
I've been distracted with developing another tooter product...
And just got the prototype running on my truck today...
It made the intake runners 12% longer and really lowered the torque curve. I can slip the clutch in first gear with no gas pedal and the truck doesn't stall out even down to just 400rpm.
The Yaris is running great...
...and It'll be on the dyno soon after we drive it a while to make sure everything gets settled in.
Old 08-14-2013, 09:14 PM   #1371
tooter
play every day
tooter's Avatar
I cut about half of the bend off of the slilcone coupling to straighten the intake because the air filter didn't need that much bend. So it's all ready to run...
Just called Harry...
...dyno test is on for Saturday.
Old 08-14-2013, 10:03 PM   #1372
Cool!
Old 08-14-2013, 10:26 PM   #1373
tooter
play every day
tooter's Avatar
...and the Tacoma hits the dyno next week if I can find the free time.
I already did the baseline dyno, so the next one will be with the tooter II.VII.
Old 08-15-2013, 07:15 PM   #1374
Viperoni
Drives: 2005 Toyota Echo
Sweet!
2006 Saturn Ion Redline
Old 08-17-2013, 05:41 PM   #1375
tooter
play every day
tooter's Avatar
On the dyno, the tooter et didn't perform any better than the regular tooter, but it didn't perform any worse either. With 111hp and 105tq the graphs are basically the same. So for all my tinkering around, I didn't actually change anything!
Old 08-17-2013, 06:53 PM   #1376
etherdude
Drives: 2012 Yaris SE 5-speed
thanks for the data...
Tooter, please remind us. How do your fully modded figures compare with "bone stock"?
Thanks, Doug
etherdude is offline   Reply With Quote
Old 08-17-2013, 07:13 PM   #1377
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
While it's disappointing to see that there isn't an appreciable improvement, it's certainly unique. Have you considered changing the runner length on a "standard" tooter for comparison?
Old 08-17-2013, 07:38 PM   #1378
tooter
play every day
tooter's Avatar
Thanks, Doug
Here's bone stock dyno runs from the dyno chart sticky thread:
The results.
Stock:
91hp
91tq
Tooter:
111hp
105tq
So with:
Intake
Throttle body
Intake manifold
Header
Axle back exhaust
I have 22% more horsepower, and 15% more torque with the stock ECU, no tuning, and regular 87 octane pump gas. Latest gasoline fillup today: 39.4 mpg.
Total cost: $1,350
Old 08-18-2013, 11:17 AM   #1379
tooter
play every day
tooter's Avatar
I'd also add that none of these modifications has altered the basic reliability economy or longevity of the engine. My wife's car is still just a regular daily driver that always needs to be in service.
Now it's just way more fun to drive...
Old 08-18-2013, 02:04 PM   #1380
etherdude
Impressive results!
Tooter,
I would estimate you have optimized the volumetric efficiency of this particular air pump. A gain of 20 hp at the wheels is awesome. Without changes to cam timing, fuel map, and injectors (meaning access to the ECU), I cannot imagine there is anything left in a naturally aspirated Yaris. Think about it...your at the crank hp is pushing 125+.
Old 08-18-2013, 03:11 PM   #1381
That bone stock dyno chart is not your car, correct? There will be natural variation in that number (note the 93 degree temps for example, warm day!) You've been a big proponent of posting charts for the same car, under the same conditions, on the same dyno, which are awesome when someone bothers to do it, as you have.
The before and after tooter dynos were especially helpful.
Tooter, how did you get the car to rev to 6500? I thought stock rev limit (as shown on the stock dyno) was 6250.
I'm also not sure the difference between SAE and STD smoothing -- anyone know?
Old 08-18-2013, 05:31 PM   #1382
mario98c
mario98c's Avatar
The stock rev limiter is 6,500rpm.
Old 08-18-2013, 09:36 PM   #1383
tooter
play every day
tooter's Avatar
Tooter,
I know nothing about the electronics and so chose to leave them totally untouched while focusing solely on the physical aspects.
And the dyno runs tell only part of the story. In normal daily operation nothing was conceded to drivability or to getting excellent gas mileage. I believe this is because I didn't alter the factory electronic engine management and instead turned my attention to the issue of flow.
Old 08-19-2013, 02:06 AM   #1384
tooter
play every day
tooter's Avatar
The other side is that there isn't any appreciable loss either, so it's break even. The et wasn't intended for sale anyways as it takes way too much work to build one. It was just to satisfy my own curiosity.
Yes, I'm considering longer runners and also a larger plenum using the et as a test bed for further experiments. This stuff is as addictive as crack. You're always asking yourself... well, what else can I do?
Old 08-19-2013, 02:07 AM   #1385
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Originally Posted by tooter View Post
So with:
Intake
Throttle body
Intake manifold
Header
Axle back exhaust
Total cost: $1,350
That's impressive considering you haven't modified any electronics and let the stock ECU make any corrections.
Tooter, I really plan on coming up in the next 2 wks or so. I'd like to meet up and talk with you about my ideas for my 1NZ-FXE. It includes a few items like the ones below...
JustDidIt is offline   Reply With Quote
Old 08-19-2013, 02:46 AM   #1386
tooter
play every day
tooter's Avatar
Sounds like fun!
PM me in advance before you come so that I can set some time aside from work, and we can explore the possibilities. Oh oh, stainless. That's a lot harder to work with than aluminum. But it's still buildable material.
Greg
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
