![]() Drives: 2007 Toyota Yaris Join Date: Jan 2010
Error code C1241 after P0010
So I got my car back from the mechanic, P0010 cleared but it shows C1241. I know nothing about repairs so can someone tell me what this means? New battery, new alternator? It's something to do with the power supply.
C1241 is an ABS brake system error indicating low or abnormally high battery voltage the the ABS ECU.
So what would have caused this after a cam sensor replacement?
If the error clears and stays away then it is likely that they turned the ignition on with something disconnected. If it doesn't clear, then I would suspect a damaged wire going to the ABS ECU.
Thanks! Back to the mechanic tomorrow.
After you get this squared away, I would suggest looking for a new/better mechanic.
I think I agree with you. I had no problems with this car until Good Year worked on it. This was actually the second mechanic in a week to work on my car.
| Error code of P0010 on diagnostic test | Stacy Travis | DIY / Maintenance / Service | 2 | 08-31-2013 08:44 AM |
| P0010 OBDII scan code | yaitsme | DIY / Maintenance / Service | 2 | 04-08-2013 11:24 PM |
| Code p0010 | Ckern67 | DIY / Maintenance / Service | 1 | 11-26-2011 10:57 PM |
