![]() ![]() ![]() ![]() Join Date: Feb 2010
Mass air flow sensor cleanin question
So I was at Orielys today to get some mass air flow sensor spray cleaner to do a pm cleaning. The clerk sugessted i put some bulb grease in the electrical plug when i put it back together. So i thought..okay, he must know what he talking about. However, when i pulled the thing apart there was no grease in the plug with multiple wires going to it. I opted not to put the bulb grease in the connection. My question is..was he correct? Is it a good idea to dab some bulb grease in this connecton?
There is a gasket around the connector to prevent water penetration. Rubber/Silicone will eventually dry out and let water in. It is a matter of time, so yeah.. i would definitely put some non-conductive grease in there. But you really don't have to...
#3 | |
Thank you.
| WTS Jet Power Flow MAF Sensor | yangjiesheng | Items for Sale by private party | 2 | 06-13-2013 02:29 PM |
| HKS Super Power Flow Reloaded Open Pod Air Filter | yuxian | Performance Modifications | 4 | 04-05-2013 12:05 AM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
| Air Flow switch problem | aucorium | DIY / Maintenance / Service | 5 | 01-15-2007 04:54 PM |
