![]() ![]() ![]() Drives: 2010 Yaris 3 door, manual tran Join Date: Jul 2013
Intake selection
Hello guys,
Back again :). I'm buying an air intake tomorrow and after searching and speaking with a couple of members I decided to gets the Injen CAI which is on sale, but I got a little scared seeing the installation instructions and the pain of having to remove the bumper to reach the filter. I was thinking about getting the aFe intake but it says, "Yaris 1.5L" and I "think" my yaris is a 1.3 litter. Not sure (3 door, manual tran, 2010, everything is manual inside )Here are the links for more reference. http://shop.microimageonline.com/aFe...L-51-11302.htm http://shop.microimageonline.com/Inj...ris-SP2024.htm Thanks for any input. |
All US Yaris have 1.5L 1NZ-FE engines, so either would be fine.
Form>Function
I have the Afe and I love it
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
I have a trd one which seems to be the best one in terms of build quality - nicely polished stainless steel .. but would go with AFE or K&N this time becasue of easier access
I think they are all pretty similar (or negligibly different) as far as gains go, so it is really all about which one you like the looks of best.
![]() Drives: scion xb Join Date: Nov 2013
I don't have a Yaris, But I do have the same motor in my XB. I have had a INJEN CAI in my car since it was a few weeks old in 2003 a decade ago...WOW time flies
Anyways I have the version that snorkels all the way down behind the running light cutout.As far as any perceivable performance gain...?? I don't think its possible to even notice a improvement, In theory I'm sure it does..but its not anything you will notice. What it does deliver is a cool intake sucking noise..if you like that. I kinda do. At least it makes the sound of performance In addition its a good looking well built unit with a resueable washable filter that I do oil IMO its important I re oil it every 3 months or so.I lost the lil sticker I was supposed to get with it for the Calif smog laws..so I have to take it off every two years and re install the stock filter setup...only takes a 1/2 hour. So Ive donbe this close to 6-7 times back to the stock filter and Truthfully...I feel nor see no power difference from one to the other after 130,000. Id like to think I'm qualified to give a accurate impression. IMO its a wash. If there is a difference its flat out down hill on the freeway, when the speedo reads a optomistic 121 mph ![]() FYI I also have a INJEN " fireball" axle back kit installed at the same time...same thing no difference in perceivable power, actually I do belive I lost a little off the line grunt..it does sound good..but the problem is when you get on it..everyone know what your doing so they floor it ...and them the inevitable humiliation of them blowing your doors off, be it either a Prius, mini van or neon...lol Unfortunately there is a reason these cars are about the same speed as a SMART CAR...at least we have fun in them regardless ![]() ![]() I had a 03 Matrix XRS with the 2zz 6 spd motor, I had Toyota install a TRD CAI...on that engine it made a "bold" difference you could feel, Unlike our motors, the XRS motor had the variable valve intake cam that could actually ingest ALOT of air and make power and rev past 7000 rpm!!!, something the Yaris/Scion motor cant really exploit "at least in stock form" Obviouslly if you have engine work, cams and or supercharger or turbo..then the rules change and it would be able to utilize the added air and add substantial "noticeable" power gains. I Don't think there is a traceable "performance" difference between TRD, INJEN or any E-Bay filter in any application, other than the theoretical design of a short ram vs, Long ram and colder air being injested. One last thing.....Obviouslly...use caution when approaching deep water..kiss of death. I think you will be happy, just don't have large expectations. Last edited by xb visitor; 11-09-2013 at 01:30 PM. |
Form>Function
on our small little motors, any intake will net you pretty much the same gains. Maybe 2-3whp overall for any intake is about all you could expect. If you dont want the extra work just get one of the top mount short rams like the AFE or K&N
Users were satisfied with both, so I guess either choice would've been fine. But, since I read about cel problems with the aFe I got the injen. I also might get some help from someone who has a bit more experience to install it.
#10 | |
Form>Function
Youll enjoy the injen no doubt, and dont forget to post pics once done! |
#11 | |
![]() ![]() ![]() Drives: 2010 5 Door Join Date: Feb 2011
But that doesnt mean i wont watch and help :) my afe threw cels but it took some fiddling with the screws on the MAF to get it right.. im CEL free now for a while now actually
lol okay |
#12 | |
#13 | |
. Therefore, the help is greatly appreciated |
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
Injen>Afe
no need, garm! Stomping on your instrument cluster rids all warning lights!
lol okay |
Form>Function
hahahahahaha
Adding to this is a bypass valve necessary with this intake?
^ Not at all.
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 06:34 AM |
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 09:11 PM |
| The great intake debate! | fmicle | General Yaris / Vitz Discussion | 74 | 10-07-2009 12:37 AM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 11:07 PM |
| Air selection intake broken? | David81 | General Yaris / Vitz Discussion | 16 | 06-29-2006 03:51 PM |
