Old 11-11-2013, 01:09 PM   #1
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
Went to the Drag Strip and this happened
This is from my 1300cc Automatic Vitz
I feel great that I won but how do I improve this time? Everything is stock at the moment
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 11-12-2013, 12:05 AM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
71+ mph in the 1/4 is good for a 1300cc auto!
As far as faster, if the 1.216 is your reaction time, you could try anticipating the green light to reduce that time. Even if you could cut that time in half, 6 tenths of a second is a lot of time to cut off your quarter without needing your car to be any faster than it is right now.
Removing any excess weight for your drag runs, like the spare tire and jack, would help. On a little light car, any removed weight will make it faster. You could also pump up your rear tires to 45 psi to lower their rolling resistance. Also run with all of your windows up and vents closed to lower the wind resistance. All these little refinements can really add up.
Greg
Old 11-12-2013, 07:19 AM   #3
Ryze268
Ryze268's Avatar
Greg
Thanks a lot for the kind words, I'll give all this a try and let you know of the improvements
Old 11-12-2013, 10:55 AM   #4
And, you beat the Civic.
That would make it nearly perfect. (.5 sec is built into that number) Difficult, but possible.
How many passes did you get?
Old 11-12-2013, 12:18 PM   #5
Ryze268
Ryze268's Avatar
It was my first and only pass, do you know if 06 Yaris headers would fit in my Vitz?
Old 11-12-2013, 12:30 PM   #6
^ that's a 2NZ-FE motor right?
Old 11-12-2013, 12:58 PM   #7
Ryze268
Ryze268's Avatar
Indeed it is
Old 11-12-2013, 08:55 PM   #8
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
what civic were you running against? unrelated, but curious.
-Derrick-
Old 11-13-2013, 06:34 AM   #9
Ryze268
Ryze268's Avatar
I think it was a US spec EG with a B15B VTEC Engine (obviously there was something wrong with it)
Old 11-13-2013, 10:33 AM   #10
We don't have a bolt-on header for the 2NZ-FE. We *think* the 1NZ header will fit the head, but I don't know about clearance or alignment with the exhaust.
Old 11-13-2013, 11:22 AM   #11
ilikerice
ilikerice's Avatar
Vtec must not have kicked in
-Derrick-
Old 11-14-2013, 07:14 AM   #12
Ryze268
Ryze268's Avatar
Yes it should bolt up the same, I'll take a pic of the stock setup when I get a chance
lol seems like it
Old 01-15-2014, 03:43 PM   #13
RJay
Drives: 2002 Toyota Yaris T-sport
As said before indeed remove everything that does not have to be in your car for it to run (I know people who take jerrycans and a fuel syphon with them to remove those extra kg's of fuel) and buy 2 sticky tires for the driven wheels whilst inflating the undriven wheels.
If you really want to go nuts on tires try and see if you can find the skinnyest rubber out there for the rear wheel..... But be carefull under breaking!
All things you can do before working on your actual -car-
And something to ponder about is that higher tire walls will give you higher top speed, but lower tire walls will convey a bit more torque to the asphalt :) Lower pressure in the driven tires will also stop wheel spin off the line to a point because the sidewall can work a bit more before the contact surface slips.
And another thing, once you're on the line with your car all warmed up, turn the heater on -full-. It will suck out all the hot air from the engine bay. It's what we did back in the bmw E30 cup.
RJay is offline   Reply With Quote
Old 01-15-2014, 06:04 PM   #14
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Take out the rear seat. It's only 4 bolts and it takes 10 mins. You will feel a difference for sure.
Old 01-16-2014, 04:13 AM   #15
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Unless im reading the sheet wrong, that Civic only topped out at 62mph?
Check out my Build thread:
Old 01-31-2014, 09:57 AM   #16
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
62.15
blazingly slow for a Honda product
agreed on reaction time, get that down
how is cold air supply ?
have a K & N or something of the like ?
