When I drive my front tires start making a humming sound, like truck tires make. It starts at 30mph and gets noticeably louder up to high way speeds. My tires aren't completely worn nor do they seem like they are wearing unevenly. They have about 35k on them. It started when I drove on a road that was a little rougher than normal. It was a freeway changing to different styles of pavement. I might have them rotate the. And see if it remedies this. It gets louder when I turn either way. Any advice? Thanks
#2 | |
Could it be the front wheel bearings (if it's not the above) ? The scenario he describes sounds similar to what I was hearing at about 110k. I was told the front wheel bearings needed to be replaced. I had them replaced, and the sound disappeared.
Wheel bearing are a possibility as well. Although with them the noise typically doesn't start all of the sudden.
Okay I'll take a look. I've been driving in them like this since the end of November. No problems so far. My car has never had a misalignment issue. And my alignment so far is still good. I hope it's not a wheel bearing. Do I need to check all four corners or just the front where the noise is coming from. In march I had planned on buying new tires after I get my tax refund. So if I need new tires it has to wait till then.
For checking the tire surface, you can just do that with your hands. Check what is accessible and then roll the car a foot and check the rest.
For the wheel bearings, usually it is just one that fails at a time, so you should be able to locate it to one corner and it it doesn't appear to be a tire issue, jack the front up, put the car in neutral with the ebrake on, and rotate and wiggle the side in question.
Alright there is nothing wrong with the tires. The wheel makes a slight grind sound when I spin it though.i think it's the wheel bearing. With the holidays coming up and me not having cash till next Friday would it be safe to drive it a minimal amount. I don't feel anything in the steering wheel. This is my only vehicle.
#8 | |
#9 | |
K got a appointment for Monday. Was quoted $275 worse case scenario for one wheel. I just want to get it fixed the place I chose is okay, not as spendy as dealer but they offer in house financing or 90 days same as cash.they also do breaks and tires. Place is called Les Shwab it's popular in the northwest. I trust their brake and suspension work/prices but will never buy tires from them. Way too overpriced. I'll let you know what happens so others can have input on this issue. Thank you guys for your help. I couldn't ask for a better place for information on my car.
K I got it fixed. It was the wheel bearing. It cost $240. Not that bad. Went to les schwab. They fixed it in 3 hours which was great. Thank you for your help.
#13 | |
| 2008 Yaris sedan ‘S’ sound deadening project. | Herbicidal | In Car Entertainment + Electronics (audio / video / alarm) | 155 | 09-04-2011 11:56 PM |
| 2011 NISSAN JUKE!! 4 dr hatch awd turbo. | marcus | Off-topic / Other Cars / Everything else Discussions | 35 | 09-12-2010 12:18 AM |
| My other sound, suspension? | N9QGS | DIY / Maintenance / Service | 2 | 10-19-2009 02:26 AM |
| Humming noise when turning the steering wheel!! Help?? | mhkritzinger | DIY / Maintenance / Service | 7 | 09-28-2009 08:27 AM |
