Old 11-23-2013, 06:58 PM   #217
Chuck G
Drives: 2010 Yaris Sedan
Originally Posted by juicyjosh View Post
115 limited by the ecu.
Yaris SE MT on TEIN S-Techs (at the time).
And definitely NO, the Yaris is NOT "stable above 90 MPH." The front springs are 10% stiffer on the SE. The shocks are the unchanged.
With an unnecessarily high stock ride height, high engine position, high battery location, high seating position, high roofline (yet with no legroom and a barely adjustable non-telescoping steering wheel), short front control arms, archaic transverse torsion beam rear suspension with NO anti-roll bar, garbage all-season no-traction constantly chirping Turanzas, delayed electronic assist steering (with less assist, yet lower steering ratio on the SE), and 70% of the vehicle's weight over the two front wheels, and no major changes since 2005, the (2012) stock Yaris is hardly "stable" at anything above 40.
You're joking!
Right Juicy?
Old 11-23-2013, 10:40 PM   #218
yarisgeo13
yarisgeo13
Drives: gloss black 5 door
Send a message via Yahoo to yarisgeo13
Nice threads about speed and how we must drive the wheels off this model. I've gotten mine '13 up to 80mph. To my home to work, there's no good stretch to get mine past the posted highway speeds! My mods as far as performance wise is on the back burner. Searching for a place to live IS way more important!!
yarisgeo13 is offline   Reply With Quote
Old 11-26-2013, 02:17 AM   #219
juicyjosh
juicyjosh's Avatar
Drives: 2012 Yaris SE MT
Thumbs up Lease is up in 2 more years! Meanwhile stacking $$$$.
Originally Posted by YeOldScallywag View Post
Your entitled to your opinion, but if you ask me I think that you are driving the wrong car. Doesn't seem like you really like it that much.
You're*
I know my impressions regarding the car differ from some but definitely not all people on this forum, although it's probably echoed (ahem) by every Yaris owner who's NOT on this forum. You're right, the Yaris isn't my flavor. But it was cheap and starts up every time - except the times when it doesn't start. But it has always started the SECOND time cranking.
I'll add that the car started experiencing clutch judder at around 4000 miles. Really, Toyota? With only 103 ft/lbs. (claimed @ 4200 rpm) of torque, and essentially nonexistent torque at ~1500 rpm, how cheap does a clutch plate have to be for this to happen on a new car that only weighs 2300 lbs?
Still looks better than a Fit, though. And I do like the gunmetal sparkly-gray SE wheels.
Originally Posted by Chuck G View Post
You're joking!
Right Juicy?
No, those are the facts. It's possible that Toyota thought the car was going to be driven by ushanka-wearing orangutans; You have to be shorter than 5'10" as per the up-close pedals, lack of legroom and non-telescoping steering wheel, with the just-out-of-reach notchy long-throw shifter, but with enough headroom to be wearing two cats on your head even with the high seat.
Last edited by juicyjosh; 11-26-2013 at 02:31 AM. Reason: Noted a grammar error, but not one of mine.
juicyjosh is offline   Reply With Quote
Old 11-26-2013, 08:52 PM   #220
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I am almost 6'3" and drive it fine and comfortably. As for the stability over 90 mph no econobox is designed to be stable over those speeds. He'll plenty of midrange and even a couple luxury sedans I have driven were a bit iffy over 85. It doesn't take a lot of modifications to make the car stable over those speeds. I feel the car is perfectly fine even at 120+ until around 126 before it felt floaty. Adding the underpanel kit fixes the issues pretty well since it causes the chassis to suck to the tarmac.
Old 12-07-2013, 12:08 PM   #221
yarisgeo13
yarisgeo13
Good info how fast this car can go but where I live. There's no good stretch to get it up past 100. The fastest I've gotten my '13 is 80. I wouldn't mind take it to a drag strip and see what it can do as far as speed is concerned.
Old 12-11-2013, 11:20 AM   #222
JimKellyfan
JimKellyfan's Avatar
I've been faster through the turns at Bristol than in my Yaris, although, that was in a Petty driving experience when I did 12 laps. In the 90's, 92 was what I glanced at once, but probably around 96 for me.
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires
TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
JimKellyfan is offline   Reply With Quote
Old 12-18-2013, 04:22 AM   #223
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
I did 180km/h on mine. Felt like it could do more but I have stupid JDM 180km/h limiter.
JudgeM is offline   Reply With Quote
Old 12-31-2013, 07:36 AM   #224
428CobraJet
Drives: '09 Yaris 3dr, 13 F150rcsb 5.0
105 plus mph yesterday following friends in 5 cyl Volvo and New mt Golf.
Shut down to 80 or so after about 5 miles.
I was building speed about like the latest Hennessey C7 video shows....but he was going 200!
2009 3dr 5speed. 98,700 miles. Yokohamas
Craig
428CobraJet is offline   Reply With Quote
Old 12-31-2013, 11:36 AM   #225
37 mph!!! ((drops mic))
Old 12-31-2013, 11:46 AM   #226
HANZO_187
#CarFiend-HANZO188
Drives: 2011 Toyota Vios
I've done 115 Todd's in mine easy. But consider this that I only do this on open highway with no one in site.
I know my car well enough. But with acold air intake, and rear seats taken out. Hitting 80 mph is a breeze, 100mph is also easy but I know it starts to shudder past 100mph. Come tax time though I'm gonna get the rest of my suspension and handling along with wheels and a few minor upgrades to get my daily.
I N S T A G R A M- @Hanzo_Stmpng_Grnds
x-Check out my build thread-x
HANZO's Build Thread
HANZO_187 is offline   Reply With Quote
Old 12-31-2013, 04:33 PM   #227
fnkngrv
fnkngrv's Avatar
Old 01-13-2014, 12:13 PM   #228
caper26
caper26's Avatar
Drives: 2010 4D Sedan 5M w/convenience
I don't think the strip will be long enough...
caper26 is offline   Reply With Quote
Old 03-12-2014, 10:46 PM   #229
fnkngrv
fnkngrv's Avatar
Maybe a landing strip....ending near a hill
At least stock anyway
Old 03-14-2014, 01:04 AM   #230
bairjo
I travel 70 miles each day and move along at 80mph for about half of that...handles great.
However, all I can say to these dudes on the links below...go for it man!
https://www.youtube.com/watch?v=dX0G7fJAuhs
https://www.youtube.com/watch?v=L2poOj-x6X0
bairjo is offline   Reply With Quote
Old 03-14-2014, 08:08 PM   #231
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
I also reached almost 115mph, and it still felt way more comfortable than the Jimny I rode once as a passenger doing 80mph (which sounded like short before final disintegration at 90mph).
On a 370mi travel some days ago, I did most of the time 90, and I didn't notion any suspicious vibrations.
Of course, I'm always aware of http://www.youtube.com/watch?v=LmRkPyuet_o when I'm doing more than 50mph.
dj92 is offline   Reply With Quote
Old 03-14-2014, 08:32 PM   #232
bairjo
you have to watch out for the walls on the freeway ...they will get you every time....even at 55mph...
Old 12-19-2016, 05:06 PM   #233
Jailbreak421
Drives: a slow yaris
102 mph, engine mods are cold air intake, 4-1 headers, and muffler delete.
Jailbreak421 is offline   Reply With Quote
Old 12-19-2016, 10:45 PM   #234
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
117 is possible, I did it once, but it was down hill with a tail wind and perfect air conditions to make the most power with what I have. Plus some angry driving. I haven't been able to do it again, the speed limiter of 115 kicks in so it wont let me play that again.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Stock Yaris as fast as stock 1982 Z28 Camaro/Trans Am!! 427chev General Yaris / Vitz Discussion 72 06-13-2012 03:20 PM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 06:06 PM
Im trying to figure out a easy way to make my yaris fast... help! nsracing Performance Modifications 61 04-11-2007 09:33 PM
