Old 12-25-2013, 09:00 AM   #19
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Wow didn't realize the axle back makes that much of a difference.
I recently switched out my Borla for my old Flowmaster and absolutely love the mid range grunt I got back. But I've never tested it...
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 12-25-2013, 12:23 PM   #20
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
That surprised me too, but I don't believe the difference in exhausts is quite that drastic, as the first dyno run was done with summer blend gas while the other was done with winter blend. The fuel definitely accounts for some of that disparity as my mileage always drops off when they switch blends.
Greg
Old 12-25-2013, 01:02 PM   #21
Still shows that at least that axle-back doesn't LOSE power in the low to midrange. I think that can be safely generalized to any axle-back that flows more freely than the stock exhaust.
Old 12-25-2013, 03:22 PM   #22
tooter
play every day
tooter's Avatar
Yes. That's a pretty safe assumption to make. It's likely because the rest of the exhaust (specifically the small midpipe) already provides enough flow resistance for decent low end torque.
I also think that the modifications I had made on my intake allowed the engine to take better advantage of the increased flow more than an engine with a stock intake, which would also increase the difference.
Greg
Old 12-25-2013, 10:22 PM   #23
TOLMACH
Drives: soarer
I am still confused about the huge difference in the air/fuel ratio (((
Old 12-25-2013, 10:57 PM   #24
tooter
play every day
tooter's Avatar
The sniffer was likely not reading correctly. It wasn't in the best of condition, and there were no other symptoms that anything was out of kilter. The car drove so good with the stock exhaust I didn't even think there would be any difference at all.
Greg
Old 12-29-2013, 12:53 AM   #25
yarisgeo13
yarisgeo13
Drives: gloss black 5 door
Send a message via Yahoo to yarisgeo13
Nice exhaust. It looks like someone wants to spin the wheels off his/her car..Cool!
yarisgeo13 is offline   Reply With Quote
Old 01-10-2014, 02:03 AM   #26
tooter
play every day
tooter's Avatar
Thanks, man.
I really like it. The stainless steel resonator tip mellowed it out nicely.
My exhaust experiment! fuji Performance Modifications 12 05-20-2009 05:58 AM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
