![]() Drives: Yaris Sport 2014 Join Date: Jan 2014
Yaris 2009 Heater Fascia
Hello, I have recently purchased a 2009 Toyota Yaris, I have installed a new head unit, the colour of the head unit is considerable different to the heating control fascia, does anyone know if I can strip that fascia (the heater) and spray it a similar colour?
I've attached a picture of it to show you what i mean also would anyone know if a 2010 steering wheel would fit? (since mine is 2009) Thanks |
Yes. You can remove the knobs from the heater control panel. With the black vertical pieces removed you simply pull back on the panel to remove it. The controls are inserted into the back of the panel and there are small plastic tabs that hold them in. Just be gentle when releasing them to prevent snapping the frame that the tabs connect to.
For the steering wheel, a 2010 wheel will work fine with your 2009.
#3 | |
I'll get it off over the weekend as have to install an adapter from the cars original radio antenna to the new head unit radio antenna port. I've posted elsewhere about the lights in this climate control unit, am I able to change the colour of them? |
#4 | |
#5 | |
Got my fascia in, replaced the whole panel actually, thanks for the help
