Old 12-26-2013, 12:08 PM   #19
problem is that in malaysia, nobody seems to sell the tanabe exhaust or the header.
Happy to ship internationally, and those parts are usually in stock.
I sometimes see really neato aftermarket parts available in Japan that no one will ever get here in the US.
I can import any product you can find from Japan. If you want to pay for it!
I'm pretty sure garm will ship wherever though i don't know how customs or taxes would be.
Thank you, yes I do, and we help minimize duties and fees as best we can.
Old 12-27-2013, 09:56 PM   #20
japle
japle's Avatar
Drives: Vitz S 2007 LB
You have somebody in japan that helps you to ship them? Can you do a direct shipment to malaysia instead of routing it to us then to malaysia? It would be a round the world for that item, lol
japle is offline   Reply With Quote
Old 12-28-2013, 12:42 PM   #21
I'm not sure. What's the part you have in mind?
Old 12-30-2013, 10:54 AM   #22
japle
japle's Avatar
Exhaust, headers, bodyparts, 4wd tranny set...
Old 12-31-2013, 02:45 AM   #23
yariseggvvti
Drives: Yaris Hatchieback
Several of us have done resonator back exhausts. just after the resonator is where the exhaust shrinks from 2" to 1.75". I went with a mandrel bent 2" exhaust with a glass packed muffler. I don't have any dyno sheets but am happy with it. it did require welding though.
I got the same set up. 2 inch from resonator to TRD muffler. The sound is okay.
I just wondering what if I delete second cat and resonator with 2.5 all the back to
TRD muffler. I believe i will lose little bit of low end and got more high end. Also, I got DC 4-1 header.
Any suggestion or has anyone done it yet.
yariseggvvti is offline   Reply With Quote
Old 01-28-2014, 12:31 PM   #24
japle
japle's Avatar
would losing the 2nd cat lose low end?
Old 01-28-2014, 01:18 PM   #25
RJay
Drives: 2002 Toyota Yaris T-sport
There are 2 cat's on these toyotas? No way.
Losing any cat increases torque, since it's basically a really thin straw the engine tries to breathe through. You might have issues with the emissions test though.
198X BMW E30 modified race car
1975 Ibanez "Les Paul custom"
RJay is offline   Reply With Quote
Old 01-28-2014, 02:29 PM   #26
tk-421
tk-421's Avatar
Drives: 5D-07-LB
The second one isn't as important as the first one, but I wouldn't remove any of them.
Old 01-28-2014, 11:29 PM   #27
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
The flow is already set by the first cat...so removing the 2nd cat is only going to gain more noise then power.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 01-29-2014, 01:24 PM   #28
Way!
Old 02-06-2014, 08:20 AM   #29
japle
japle's Avatar
Way!
Yes, thats the stock yaris exhaust system that is on everyones beloved, including mine. I wouldnt mind removing the 2nd cat if it does increase torque in anyway, besides in malaysia there is no such a rule for emisions... the rules here are all bendable. Can anyone here prove that removing the 2nd cat increases or decreases power?
2nd issue is, i want an axleback exhaust, but i just cant find any here in malaysia, so it would have to be custom. Any suggestions? Mine is an automatic,.
3 issue is, changing the cat, i would like to change the 1st cat to a high flow, any suggestions on that too?
Thanks guys
Old 02-06-2014, 09:54 AM   #30
Isn't it 1 cat and 1 resonator, not 2 cats?
Old 02-06-2014, 11:56 AM   #31
^ No. Look at the diagram, you'll see both cats before the resonator (#5).
Old 02-07-2014, 12:07 PM   #32
japle
japle's Avatar
Thanks guys
Bump....
Old 02-16-2014, 09:27 AM   #33
japle
japle's Avatar
Had this installed yesterday... noticeable gain in torque and reduction in engine grunt, especially when uphill drive, and much more smoothness, i mean it wont hold back the car when i release throttle....
Its a 4-2-1.
Old 02-17-2014, 12:39 AM   #34
DJYojimbo
Drives: 2012 Grey Toyota Yaris SE
Weapon r header?
Upgrades: AFE SRI. Tanabe Touring Medalion Axleback exhaust. Micro Image OEM Sized Lightweight Pulley. DC Sports header.
DJYojimbo is offline   Reply With Quote
Old 02-17-2014, 01:23 AM   #35
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by DJYojimbo View Post
Weapon r header?
No. But it's a smoother flowing design than weapon R...
Who makes that?
Greg
Old 02-17-2014, 08:00 AM   #36
japle
japle's Avatar
A company here called undersix exhaust. Malaysian made.
And its very light...
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 09:02 AM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 10:23 PM
Aftermarket exhaust systems that do not rub on the road! fuji Performance Modifications 10 04-28-2009 07:22 AM
Performance exhaust systems for yaris aucorium Performance Modifications 6 08-16-2006 09:12 AM
