Old 04-08-2007, 03:13 PM   #199
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
OxyG3nE is offline   Reply With Quote
Old 04-08-2007, 03:16 PM   #200
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Replied to your PM as well. Its not my busniess, so you have to order direct. Thanks.
Old 04-08-2007, 03:17 PM   #201
OxyG3nE
i only need to buy the 194 wedge or i need to specify its for the yaris ?
Old 04-08-2007, 03:23 PM   #202
Chris07LB
Chris07LB's Avatar
HERE - http://www.hileds.com/194wedge.html
Its a 194 fittment, so thats what you ask for.
Old 09-13-2007, 10:34 PM   #203
OgDogg
Gas Guzzler
OgDogg's Avatar
Drives: 07 Yaris Sedan S
Originally Posted by Chris07LB View Post
I did adjust the lights down just a hair (half a turn counter clockwise), just because i "thought" they might be a little high.
Anyone got a picture of exactly where this headlight adjustment is? Or perhaps someone would care to post a DIY to help keep the roads a little safer. :)
OgDogg is offline   Reply With Quote
Old 09-14-2007, 09:32 PM   #204
angeleyes
YARIS CHICA
Drives: black 07 yaris sedan
Originally Posted by OxyG3nE View Post
so i want HID kit but i wwant to know if it will blind everyone that i cross on the road and what K i should use to have the more white possible .. i dont want purple or blue
5000k is the white, and the 4300k is white. I got mine from http://http://www.ultrabrightlights.com/
They are a great company. The owner of the company answers any questions you have, and they have good prices. And no you dont blind anyone, but some people think they are your brights, and flash at you.
Hope that helps
angeleyes is offline   Reply With Quote
Old 09-16-2007, 10:07 PM   #205
OgDogg
Gas Guzzler
OgDogg's Avatar
FYI, on the sedan it's an 8mm nut you have to tighter/loosen in order to adjust the headlights vertically.
Old 09-16-2007, 10:16 PM   #206
uncleyaris
After trying just to change blubs, I be afraid to install HID's, it's so tight for space. Are the instructions that come with most kits easy to follow? IS it a big job?
Old 09-17-2007, 12:51 AM   #207
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Still kickin around the idea of hid's. Who all has the bi beam kit and what is the brand and do they fit ok without any modding of the assembly?
Old 09-17-2007, 10:32 AM   #208
OgDogg
Gas Guzzler
OgDogg's Avatar
I have the hi beam kit and it fits perfectly. You just have to turn the rubber piece behind the bulb inside out to fit the larger bulb casing.
As far as installation goes... It's just as easy as changing the light bulbs only you have the added step of mounting the ballasts.
Old 09-18-2007, 04:42 AM   #209
slvryaris
slvryaris's Avatar
What does everyone think of these kits on EBay??
http://cgi.ebay.com/ebaymotors/HID-B...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/XENON...spagenameZWDVW
I know low price soooo........Has anyone had problems with the Bi beam fitting. I Imagine they would all be of correct size and not oversized.
Old 09-19-2007, 09:07 PM   #210
driver centric
I know right?
driver centric's Avatar
Drives: 07 Bayou LB
Hey, see my post at http://www.yarisworld.com/forums/showthread.php?t=8922.
I tested a bi-xenon kit from Xenonlink.com and it did not fit in my LB's headlight setup. The springs that hold the bulb in would not work with the HID bulb. I'm sending the kit back for a refund.
I have ordered another kit from xenithxenons.com, who have tested their bi-xenon kit on Scion xBs, which also use H4 and have a similar spring retaining system so hopefully this kit should be compatible with our cars.
I'll let you guys know what the results are.
-Kev
07 Bayou Blue Liftback 5-spd manual
driver centric is offline   Reply With Quote
Old 09-26-2007, 12:47 AM   #211
slvryaris
slvryaris's Avatar
Did anyone ever figure out how to adjust the headlight??? Or do you just tuen that 8mm nut?
Old 09-26-2007, 06:07 AM   #212
Chris07LB
Chris07LB's Avatar
Pop your hood.. look for a black round barrel on the inside (engine side) of the light housings, with a white + in the center.. thats your adjuster.
Old 09-26-2007, 07:28 AM   #213
slvryaris
slvryaris's Avatar
Right on. I posted the comment when i was at work and in a hurry. I just checked the manual online and seen it, but for some reason I couldnt find it before. I guess I will try to lower the headlights before I give up on the HID's until someone starts selling retrofitted headlight assemblys so I dont have to mess with it. Also Chris I was curious how you have the stock assemblys and no one has flashed you. Is it in the bulb for some people like with the glare shields or de people re aim??? I just have no idea how people have HID's without retrofitting or lowering the assemblys.
Old 09-26-2007, 07:31 AM   #214
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
This here:
Old 09-26-2007, 08:34 AM   #215
slvryaris
slvryaris's Avatar
Sedan is different. Just went outside andfound it. It looks like a light grey wheel with a 8mm nut in the middle. I just turned it clockwise and lowered my lights. Looks a 100 times better.
Old 02-28-2009, 01:13 PM   #216
Soccer_Yaris
Drives: Toyota Yaris RS
I am now returning the 8000K hid lights back to the store. After installing the lights I found out that I cannot have these lights working on my car with the DRL module. In Canada its the law to have DRL ( Daytime running lights). It would be a $360 ticket without it. So I contacted the supplier and he told me to return it. Thats $300 bucks back in my wallet!
Soccer_Yaris is offline   Reply With Quote
