Old 02-11-2014, 03:28 PM   #1
blackvitz
Drives: 1.3 2sz-fe
Vitz 2sz-fe air intake?
Anyone can give some tips if a custom air intake can be done for a vitz 1.3 2s-fe 2006 ? if yes any problems with maf sensor? K&N and other brands never produced something, so I was thinking of doing a custom one. So far i have a cone filter attached to the plastic box but i wish to make a stainless steel pipe attached to the throttle body so I can improve performance and sound. opinions appriciated. Thanks!
blackvitz is offline   Reply With Quote
Old 02-11-2014, 04:11 PM   #2
Use aluminum, not stainless steel for the pipe.
You should have no issues custom fabricating just as long as you keep the inside diameter of the pipe the same as OEM. Use of a different diameter piping almost always with throw a code.
Is this what your engine looks like?
or this?
Old 02-11-2014, 05:01 PM   #3
blackvitz
Drives: 1.3 2sz-fe
my engine is the first picture. Japanese and european yaris are like that.
Old 02-11-2014, 05:24 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
I would not be surprised if one could not use honda civic intakes cos they run of the back and top ..its the sensor that u hqve to worry about its placement.... pvc pipes from a hardware store work good too most are heat resistant and dont hold heat like aluminum so more cooler air gets in.
Old 02-11-2014, 10:19 PM   #5
japle
japle's Avatar
Drives: Vitz S 2007 LB
honestly, i rather just throw in a drop-in filter and move on, reason is that the original piping is a cold air intake by itself, jusdging from the pic, correct me if i am wrong, unlike the 2007 vitz, which is just a loop, not connected to the cold air outside...
japle is offline   Reply With Quote
Old 02-12-2014, 07:20 AM   #6
blackvitz
Drives: 1.3 2sz-fe
what I have right now is a cone filter attached. I removed the pipe and attached the filter to the box I removed also the stock one from the box. its ok but it is not attaced direct to throttle body, so I can gain more power I think.
Just installed air intake on 1.5L! E3pO Performance Modifications 29 02-11-2012 09:19 PM
FS: AFE Air Intake System (Cold Air Intake) jjbG35yaris Items for Sale by private party 7 04-01-2011 02:58 PM
Armchair theory - extreme cold air intake. Beer Jammer Performance Modifications 40 08-17-2010 02:00 AM
