Old 01-31-2009, 10:59 AM   #73
ZING
ZING's Avatar
Drives: Yaris '09,GTi '09, BMW 3.30ci
bump
ZING is offline   Reply With Quote
Old 02-14-2009, 05:38 PM   #74
pariahdecss
Yarisomniac
pariahdecss's Avatar
Drives: 2009 5spd LB
Yes it can be done in the 09 - I just changed my speedo gauge backlighting from orange to blue using these from eLed :
http://www.eled.com/product.asp?cata...d=epl3015pbc-a
They are slightly bigger than what Vodkalush recommended in his DIY but they worked fine and were easier to work with (slightly). The problem I ran into was the clock on the base 09 LB gets its color from the plastic housing it is in, so changing the LED's would not fix that. What I did was buy some blue 1/8 inch transparent plexiglass and use that to change the clock color. I cut out a window in the orange plastic part around the clock and replaced it with a small piece of blue plexi that I got here:
http://www.estreetplastics.com/Trans...Sheet_s/58.htm
Cost me like $3 plus the LED's and overall was pretty easy - Use search to find the DIY from others that changed their gauge color lighting
pariahdecss is offline   Reply With Quote
Old 02-16-2009, 10:06 AM   #75
Jerkratt
Jerkratt's Avatar
plan on doing this in the neer future
"It hurts more when its wet"
Old 04-25-2009, 09:21 PM   #76
CanadianHiFive2
Drives: Sedan
ok so i know i can order the bulbs from this website
http://autolumination.com/74.htm
but exactly which bulbs is it because there a tri-power and some matrix II so if someone could tell me that would be great
I also realize that this thread is really old and im hoping someone will get this still
CanadianHiFive2 is offline   Reply With Quote
Old 09-21-2009, 12:38 PM   #77
Split
Drives: 2008 Yaris Sedan
Question
Originally Posted by vodkalush View Post
Once again if you go with a bulb it needs to be:
Neo - Wedge Instrument Panel Bulb
and if its a led:
Neo - Wedge Instrument Panel LED Type A/B (C should work aswell)
can anyone confirm if Neo - Wedge Instrument Panel LED Type C works?
It should look best since its 3LED.
Split is offline   Reply With Quote
Old 05-27-2010, 11:35 PM   #78
joeljcruz86
Little Eggy
joeljcruz86's Avatar
Drives: Toyota Yaris Liftback 3DR 2009
Send a message via AIM to joeljcruz86
Hey, I bought bulbs from Superbrite but when i try to swap out the bulbs in the stock base, it seems the bulb won't budge out of it's own base. Is there anyway for me to take it out? unfortunately the base i bought is bigger than the stock ones. 5mm. Thank you!!
joeljcruz86 is offline   Reply With Quote
Old 05-28-2010, 01:04 AM   #79
joeljcruz86
Little Eggy
Nevermind, they finally budge. except now i broke off 2 out of the 3 bulbs the two prongs. So now I have to somehow manage to solder them back. Or just by another set
Old 06-22-2013, 10:10 PM   #80
fase4
Drives: Yaris TS 05
Thread revival! I'm planning doing this on my little car ;) anyone know where I can get the colours condom?
fase4 is offline   Reply With Quote
Old 03-05-2014, 02:42 PM   #81
jasonk1123
Drives: Toyota Yaris 5 door hatch
Ok so I played around with the bulbs on my 08 Yaris, the green in the car is crappy if you ask me... So i installed a High Bright LED, this is just a normal LED that has a 999ohm resister, it involves a bit of soldering(if you want it to be permanent) and ALOT of patience, I will attach the photos, the top switch is obviously the one that i replaced https://www.dropbox.com/s/zoqtlanezy...witches.jpg?m=
If there is anyone out there that would know how to(if possible) change the colour of the radio and its buttons, once again i want them to be WHITE :)
There are no Yaris drivers, only Yaris LOVERS
jasonk1123 is offline   Reply With Quote
Old 03-05-2014, 02:51 PM   #82
jasonk1123
https://www.dropbox.com/s/u1y03gxb1q2fa42/Radio.jpg
Old 03-05-2014, 03:49 PM   #83
I changed a radio to white. It is a pain in the butt to do so, as there are over 40 crazy tiny surface mount LEDs in the radio face.
Old 03-06-2014, 12:13 AM   #84
jasonk1123
now that looks neat... Good job CTscott, do you know where i can get hold of these ''tiny surface mount LED's"?
Old 03-06-2014, 12:38 AM   #85
Below is a link to the ones I used (1.6mm x 0.8mm):
http://www.mouser.com/Search/Product...-VLMW1300-GS08
Old 03-06-2014, 01:27 AM   #86
jasonk1123
Thanks
Old 03-06-2014, 05:29 AM   #87
jasonk1123
LOL so i broke the fan switch... If i put 1 on then the air con indicator light works( but no fan) and then 2 3 &4 the air con indicator light switches off and the fan doesnt work... Does anyone have any ideas?
Old 03-06-2014, 07:26 AM   #88
I would have to see what you did on the back side of the knob. You may have created a solder bridge when you added your LED.
Old 03-06-2014, 07:40 AM   #89
jasonk1123
Ah I will double check that particular one, the other two i found a creative way to change the bulb with one that they sell here for park lights, fits into the original fitting, will change that when i get home from work in about 3 hours :(
Accessory Bulb Types, anyone know? Ayka Cosmetic Modifications (Exterior/Interior) 135 04-29-2007 09:33 AM
