Old 03-21-2014, 07:33 PM   #1
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
max wheel spacers on stock studs ?
was thinking of spacing my rear wheels out by 5mm that would take it from 42 offset to 37 ...just wondering if i have to get longer studs also do they or will the spacers cos a problem with hub bore.
Old 03-21-2014, 08:18 PM   #2
I have a set of 10mm rear hub spacers, if you are interested in going that route, instead of using wheel spacers. 5mm wheel spacers would likely be fine. The key is that with your wheels in place that you have a significant amount of threads available for the lug nuts. SAE spec is a minimum of 1/2" of threads into the lug nuts.
Old 03-21-2014, 08:35 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
like the idea of hub spacers except when it comes to winter that is when i prefer wheels back in keep crap of car .... wonder what other toyotas run in length for stud , since i work with Toyotas i should be able to see what is just bit longer.
Other question is ...is there enuf hub sticking out to still keep the wheel in center bore...with wheel spacer.
Old 03-21-2014, 10:50 PM   #4
5mm works with stock studs. No, there is not enough hub sticking out.
Old 03-21-2014, 11:08 PM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
ok and ty ...so how do u go around dealing with hub bore...guess i would have to get specific spacers with right hub bore...no generic .
Old 03-22-2014, 12:14 AM   #6
^ Best to get spacers with the correct hub bore. H&R and Ichiba are my preferred brands to sell.
5mm is maximum recommended if you are keeping your stock lug studs.
Both of those brands include the longer studs if you get thicker spacers.
Old 03-25-2014, 01:57 AM   #7
coheed
Drives: 08 BB LB
It really depends on the wheel you are running. When I had my ICW's 5mm was the max I could run. But with the Bottle Caps I have now I safely run an 8mm.
Old 04-04-2014, 02:54 AM   #8
eablola69
Drives: 2007 Yaris 4-door Hatch
CTScott:
I'm interested in your rear hub spaces - are these the ones that go behind the rear hub? But the thing is I'm from Manila, any experience shipping them out here?
eablola69 is offline   Reply With Quote
Old 04-04-2014, 01:16 PM   #9
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
like ur idea of wheel spacer more i think about it ...only issue would be removing the hubs with out damage ...the are original and have seen few canadian winters and wheel hub bearings are not cheap.
Old 04-04-2014, 01:52 PM   #10
Originally Posted by eablola69 View Post
CTScott:
No problem at all shipping to the Philippines. Shipping would be $25 by USPS International Priority, which would arrive in 6-10 business days.
Old 04-04-2014, 01:53 PM   #11
The car that I removed them from was the one with the completely disintegrated A-Arm bolts. The hub bolts were actually easier to remove.
Old 04-11-2014, 12:29 AM   #12
eablola69
Riding on this thread because it's on "rougly" the same topic.
My question then is, how thick would the bolt on hubcentric spacers be needed in order to clear the stock studs? Would 15mm be enough? - or does it have to be atleast 25mm?
I haven't decided whether to use the penguin spacers, my existing non-hub centric wheel spacers or to get new hubcentric bolt-on wheel spacers.
One thing that is very favorable for me is if I don't have to remove anything and just bolt on the spacers and then the wheels. Hence, the question.
***My wheels don't have the provisions on the back side in order to mount with protruding studs on the bolt on spacers.
two 5mm billet wheel spacers for sale... again tooter Items for Sale by private party 2 03-02-2014 03:04 AM
Stock Wheel Covers barryware Willing to Buy by private party 5 11-04-2008 02:22 PM
Stock Wheel Covers? barryware Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 11-04-2008 11:03 AM
stock wheel wushumasterku Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-24-2007 12:52 AM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
