Old 04-01-2014, 05:35 PM   #109
Originally Posted by Stenis View Post
Hello new here / anybody know if it possible to install Cruise Control to a Yaris 2012 hybrid XP13M(A) from Europé.
Yes. As mentioned above, cruise is an option of the Yaris Hybrid, so they should all be setup for it.
Old 04-04-2014, 03:53 PM   #110
Stenis
Drives: Hybride
Originally Posted by scmoky View Post
Ask CTScott, but I think that is possible, because in our country the hibrid can have CC in stock new car. You have 1.5l engine?
Yes i have 1.5l Engine. I have asked an toyota dealer and they said it cost about 1250 usd to fit CC in my car.
Stenis is offline   Reply With Quote
Old 04-04-2014, 08:35 PM   #111
Remove the lower steering column cover and snap a picture of the black connector that plugs into the spiral cable assembly (the black plastic ring behind the steering wheel that allows the connections within the steering wheel to rotate). My bet is that the wires are present for cruise control, so all you will need to do is to add the stalk under the airbag.
Old 04-05-2014, 03:48 PM   #112
Stenis
Drives: Hybride
Ok i will do so. My understanding is to remove the cover for CC take a picture. Do i need to remove airbag? for the picture? I will try to do so and take a picture soon and hope for a good reply
Old 04-05-2014, 04:19 PM   #113
No. Just remove the two screws that are exposed by turning the steering wheel to either side and the one down by the tilt lever
Old 04-05-2014, 07:05 PM   #114
scmoky
Drives: Yaris 2012
And check with you VIN number and model, if under electrical categorie is cruise control(auto drive) option.
webpage http://www.toyodiy.com/parts/
scmoky is offline   Reply With Quote
Old 04-27-2014, 08:24 AM   #115
Stenis
Drives: Hybride
Hi CTScott
Sorry for the late reply. Took some pictures under the wheel, hope that you can see someting i can't, hopefully you can tell if the wires are present or not?
//Stenis
Old 04-27-2014, 09:14 AM   #116
The connector of interest is the black one at the top left of this picture. I see by the number of wires that you have steering wheel audio controls. I can't see all of the wires, but the blue one looks like it is in the correct position.
Old 04-27-2014, 01:10 PM   #117
Stenis
Drives: Hybride
OK I WILL TRY TO TAKE A BETTER PICTURE // BACK SOON
AND THANKS AGAIN FOR ALL THE HELP
Old 04-29-2014, 12:17 PM   #118
rc_osu
Drives: 2012 Yaris Sedan
Hi!
I just bought a 2012 Yaris and so far it's great, but it too lacks cruise control (among a few other things, but that's the big one). A google search for how to add it brought me to this forum, so I thought I would see if there are still parts available! I'm not very good with cars and the terminology involved so please forgive me if I ask dumb questions. The basic extent of my skills are I can hold it, or I can go get it! So I'm hoping I can learn a little bit about this too.
The Yaris I have isn't like the ones in the pictures though, it has the gauges in the center like fredansandy described.
If you have parts available still for it, could you let me know?
Thanks!
rc_osu is offline   Reply With Quote
Old 04-29-2014, 01:34 PM   #119
Originally Posted by rc_osu View Post
Hi!
Thanks!
Your 2011 Sedan is really a 2011 as far as cruise control goes. The sedan did not get the 2012 revision that the liftback did. I just shot you a PM with the info on the parts.
Old 04-30-2014, 07:54 AM   #120
Stenis
Drives: Hybride
Hi again, CTscott
Took some more pictures today. Totaly are there 6 cables to this connection. Cables colour are blue, pink, red, black, brown and light brown.
Can you tell if my car is ready for cruise control.
Thanks again // Stenis
Attachment 53400
Attachment 53401
Attachment 53402
Old 04-30-2014, 08:58 AM   #121
Hi again, CTscott
The beige and brown wires in pins 1 and 2 are the cruise control wires, so you are good to go for installing cruise control. If you are interested I sell the stalk with wiring harness and mounting screws for far less than dealer price. Even with shipping to Sweden it would be quite a bit less.
Old 05-15-2014, 02:06 AM   #122
geoded
geoded's Avatar
Drives: Yaris MY2012 - 1ND-TV
In this picture, which is 12V +, after switch ON? Please?
geoded is offline   Reply With Quote
Old 05-15-2014, 06:47 AM   #123
Nothing visible in that picture is switched +12. Below that picture is the connector for the ignition switch and the pink wire on that connector is switched +12.
Old 05-15-2014, 03:04 PM   #124
geoded
geoded's Avatar
Hi CTScott, please tell me which is the color wire coming out of the 12 + immobilizer when the switch is ON
Old 05-15-2014, 03:24 PM   #125
You should really have posted your questions in a separate thread, as this is not cruise control related, but the 12 volt immobilizer power wire is the pink wire on the black connector at the end of the black plastic section of the ignition switch assembly.
Old 05-15-2014, 06:16 PM   #126
Zantiszar
Drives: Toyota Yaris 2014 stocky
Hello CTScott after about reading the whole lot of posts I wanted to ask you will this work on a 2014 5 door model L Yaris it's has a 1.5L engine on it and it's an automatic drive model.
I'm curious since my dash looks a lot like yours and for long trips CC would be very useful especially when visiting the family across the island :D your input is much appreciated
Sent my iPush 4s?
Zantiszar is offline   Reply With Quote
cruise control. 2012
