Old 04-05-2014, 08:05 PM   #127
scmoky
Drives: Yaris 2012
And check with you VIN number and model, if under electrical categorie is cruise control(auto drive) option.
webpage http://www.toyodiy.com/parts/
scmoky is offline   Reply With Quote
Old 04-27-2014, 09:24 AM   #128
Stenis
Drives: Hybride
No. Just remove the two screws that are exposed by turning the steering wheel to either side and the one down by the tilt lever
Hi CTScott
Sorry for the late reply. Took some pictures under the wheel, hope that you can see someting i can't, hopefully you can tell if the wires are present or not?
//Stenis
Stenis is offline   Reply With Quote
Old 04-27-2014, 10:14 AM   #129
The connector of interest is the black one at the top left of this picture. I see by the number of wires that you have steering wheel audio controls. I can't see all of the wires, but the blue one looks like it is in the correct position.
Old 04-27-2014, 02:10 PM   #130
Stenis
Drives: Hybride
OK I WILL TRY TO TAKE A BETTER PICTURE // BACK SOON
AND THANKS AGAIN FOR ALL THE HELP
Old 04-29-2014, 01:17 PM   #131
rc_osu
Drives: 2012 Yaris Sedan
Hi!
I just bought a 2012 Yaris and so far it's great, but it too lacks cruise control (among a few other things, but that's the big one). A google search for how to add it brought me to this forum, so I thought I would see if there are still parts available! I'm not very good with cars and the terminology involved so please forgive me if I ask dumb questions. The basic extent of my skills are I can hold it, or I can go get it! So I'm hoping I can learn a little bit about this too.
The Yaris I have isn't like the ones in the pictures though, it has the gauges in the center like fredansandy described.
If you have parts available still for it, could you let me know?
Thanks!
rc_osu is offline   Reply With Quote
Old 04-29-2014, 02:34 PM   #132
Originally Posted by rc_osu View Post
Hi!
Thanks!
Your 2011 Sedan is really a 2011 as far as cruise control goes. The sedan did not get the 2012 revision that the liftback did. I just shot you a PM with the info on the parts.
Old 04-30-2014, 08:54 AM   #133
Stenis
Drives: Hybride
Hi again, CTscott
Took some more pictures today. Totaly are there 6 cables to this connection. Cables colour are blue, pink, red, black, brown and light brown.
Can you tell if my car is ready for cruise control.
Thanks again // Stenis
Attachment 53400
Attachment 53401
Attachment 53402
Old 04-30-2014, 09:58 AM   #134
Originally Posted by Stenis View Post
Hi again, CTscott
The beige and brown wires in pins 1 and 2 are the cruise control wires, so you are good to go for installing cruise control. If you are interested I sell the stalk with wiring harness and mounting screws for far less than dealer price. Even with shipping to Sweden it would be quite a bit less.
Old 05-15-2014, 03:06 AM   #135
geoded
geoded's Avatar
Drives: Yaris MY2012 - 1ND-TV
In this picture, which is 12V +, after switch ON? Please?
geoded is offline   Reply With Quote
Old 05-15-2014, 07:47 AM   #136
Nothing visible in that picture is switched +12. Below that picture is the connector for the ignition switch and the pink wire on that connector is switched +12.
Old 05-15-2014, 04:04 PM   #137
geoded
geoded's Avatar
Hi CTScott, please tell me which is the color wire coming out of the 12 + immobilizer when the switch is ON
Old 05-15-2014, 04:24 PM   #138
You should really have posted your questions in a separate thread, as this is not cruise control related, but the 12 volt immobilizer power wire is the pink wire on the black connector at the end of the black plastic section of the ignition switch assembly.
Old 05-15-2014, 07:16 PM   #139
Zantiszar
Drives: Toyota Yaris 2014 stocky
Hello CTScott after about reading the whole lot of posts I wanted to ask you will this work on a 2014 5 door model L Yaris it's has a 1.5L engine on it and it's an automatic drive model.
I'm curious since my dash looks a lot like yours and for long trips CC would be very useful especially when visiting the family across the island :D your input is much appreciated
Sent my iPush 4s?
Zantiszar is offline   Reply With Quote
Old 05-15-2014, 07:53 PM   #140
Sent my iPush 4s?
Yes - Cruise control would work with no problem on your 2014. For your automatic you would only need the stalk with harness and mounting screws.
Old 05-16-2014, 03:31 PM   #141
geoded
geoded's Avatar
I am looking for the connector on the left in the photo below. You will remove the two screws behind the steering wheel and the one by the tilt lever to remove the lower cover.
This is my car connector, (1ND-TV), has beige and brown is, but cruise control does not work. :-)
Old 05-16-2014, 03:34 PM   #142
Correct - The 1ND-TV engine computer does not have cruise control capability built into it.
Old 05-16-2014, 03:46 PM   #143
geoded
geoded's Avatar
But the harness exist :-)
Old 05-16-2014, 04:00 PM   #144
Yes. Toyota was not nice to include the wires but not the function.
Tags
cruise control. 2012
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
