Old 03-20-2014, 05:28 PM   #19
Ecogeek
Ecogeek's Avatar
Drives: 2008 Yaris
It was a good day today! I put on a spoiler on....
And bought some lowering springs. Haven't installed them yet.
Ecogeek is offline   Reply With Quote
Old 03-20-2014, 05:35 PM   #20
Mongoose7
Drives: 2007 Yaris HB
Which spoiler is that???
Mongoose7 is offline   Reply With Quote
Old 03-20-2014, 07:07 PM   #21
Ecogeek
Ecogeek's Avatar
Drives: 2008 Yaris
It's a knockoff RS spoiler? I think.... I also got a stubby antenna... My car is paid off so I can start putting some money into my car! I also am saving for a house so nothing to crazy!
Old 04-09-2014, 12:14 PM   #22
Ecogeek
Ecogeek's Avatar
Drives: 2008 Yaris
Chicka chicka yeah, Got some sprangs and strats!
M2 lowering springs (1.5" drop) picked them up for $100...
KYB Struts and shocks for $173!
According to what I have read the KYB are fine up to 1.5 inch drop... Can anyone verify this? or did i just pull that number out of my A$$? lol Before I install I want to double check.
Old 04-09-2014, 04:27 PM   #23
TerenceCruz
Drives: 2011 Toyota Yaris
Great pick up!! Can't wait to see it lowered!
TerenceCruz is offline   Reply With Quote
Old 04-09-2014, 05:18 PM   #24
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
I'm on KYB and 1.8 inch drop for the last 40,000km or so and all good they are well priced and work well
Old 04-09-2014, 05:22 PM   #25
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Don't forget to cut ur bump stops by how much u lower the car
Old 04-18-2014, 10:45 AM   #26
Ecogeek
Ecogeek's Avatar
Drives: 2008 Yaris
I can't find how much I'm supposed to cut the bump stop. I'm dropping my car 1.5 inches. How much do I need to cut off ?
Sent from my SPH-L710 using Tapatalk
Old 04-18-2014, 11:17 AM   #27
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
1.5 inch same as the drop or halfway
Sent from my XT1032 using Tapatalk
Old 04-18-2014, 12:05 PM   #28
Ecogeek
Ecogeek's Avatar
Drives: 2008 Yaris
Awesome thanks!
Old 04-18-2014, 06:48 PM   #29
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
no need to cut the bump stops.
Colin Chapman disciple
Old 04-18-2014, 07:11 PM   #30
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
U always should cut bump stops ...think about it car droops 1.5 inch with a bump stop made for stock ur travel and ride will suffer on stock bump stop size basically ull loose travel and hit the stops ....kind of like riding on them and not ur springs if u say u go even lower .
Old 04-18-2014, 09:02 PM   #31
why?
why?'s Avatar
Drives: Yaris LB
except that isn't always the case anymore. Plenty of people have lowered Yaris and didn't touch the bump stops and have never reported any problems. Cutting the bumpstops is an old thing like so many car ideas that does not need to be followed any more.
Old 04-18-2014, 09:32 PM   #32
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Sorry but I do not agree with u has nothing to do with old school it's simple physics ...just look over how a strut works and what the bump stop is intended for ...ur limiting ur suspension by not cutting u will notice the ride difference on bad roads .
Old 04-18-2014, 10:13 PM   #33
why?
why?'s Avatar
Drives: Yaris LB
If the ride sucks it has nothing to do with the bump stops and has everything to do with crappy suspension tuning. If you are bottoming out your suspension is screwed up.
Bump stops aren't there just for the hell of it.
And yes, it is old school. Everything is much better now than it use to be. Suspension components are a million times better.
At this point in time cutting bump stops is just a personal choice, with no real relevance to actual performance except it could be more dangerous, but probably isn't. Like I mentioned, we've got 7 years of data and many lowered Yaris, some didn't touch there bump stops, some did. No one has ever come back either way and said they destroyed the car, or damaged the car in any way, or made the ride worse or better, because they cut their bump stops or didn't touch them.
Old 04-18-2014, 10:26 PM   #34
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Just look at the physical aspect of the application ...that's all .
Old 04-18-2014, 11:05 PM   #35
sex
sex's Avatar
Drives: 09 5DR
OP, what are those tubes in your bottom grill? Brake ducts?
sex is offline   Reply With Quote
Old 04-19-2014, 09:27 PM   #36
Ecogeek
Ecogeek's Avatar
Drives: 2008 Yaris
Alright it is all done buying two new sway bars... I had to cut one off, it was really corroded. So I figured I'd get the otherside done too.
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 10:56 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-15-2013 11:44 PM
Kids are quick SilverBack Off-topic / Other Cars / Everything else Discussions 11 08-21-2009 12:49 AM
Help me me build my budget system =) YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 22 11-25-2008 02:33 PM
