![]() Drives: Toyota Yaris 1.4 D4D 2006 MMT Join Date: Apr 2014
Yaris, very mysterious, electrical problem (VIDEO) - SOLVED
Hello, I am having a big electrical problem with my Yaris 1.4 D4D 2006. As you can see in the video, when driving suddenly everything start to blink, gear change to Neutral, radio off, and some seconds later everything works again.
Is impossible to reproduce the problem, that occurs from time to time, not always. Tha battery is well connected and seems to be OK (at least green light in the battery hole and not problems to start). I appreciate a lot any advice. https://www.youtube.com/watch?v=FB8ZSdRJFtU Regards Last edited by csrblanco; 07-09-2014 at 04:03 PM. |
![]() Drives: '08 Yaris Join Date: Apr 2014
Check the ground wire to the chassis, not at the battery. Have you changed anything electrical recently? Headlights, stereo, etc...
Thank you marauder.
Nothing, I've never change or install anything. |
Could be a simple fault in a ground wire to the engine, etc...
Look up technique for testing your vehicle's earth/ground system for faults. Try this article, see if this helps you any. http://www.popularmechanics.com/cars...enance/4314662 |
Great. Thank you. I will have a look to that info.
Besides checking for loose ground connections, check the connectors on the under side of the positive battery terminal to make sure they are not loose or corroded.
SOLVED. The problem has been solved just with a new battery. It seems the old battery don't have enough power to support all the electrical demands.
Thank you!. Last edited by csrblanco; 07-09-2014 at 05:06 PM. |
| Supercharged Yaris: Greatest Yaris video ever made. TRUST ME! | PETERPOOP | Photo-Video-Media Gallery | 54 | 08-29-2013 03:27 PM |
| Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c | Yar Is Word | Third Gen Yaris General Discussion | 27 | 09-06-2012 11:37 PM |
| Electrical System problem 2006 Yaris | Ivriniel | DIY / Maintenance / Service | 12 | 05-10-2010 02:55 AM |
