Old 04-26-2014, 02:16 PM   #1
detroiter
detroiter's Avatar
Drilled stock airbox
I was cleaning out the garage and found a second stock airbox configuration that I forgot I had. I was thinking about the airbox mod that's been here on the forum for a long time and figured, why not? So ended up drilling nickle sized holes in 3-5 lines all the way around the lower box. Needless to say, I wish I would have done this a long time ago, reminds me of the growl and sound the AFE intake gave me but obviously as a much lower price. That's not to say the AFE or any other intake is a bad thing, they look much nicer than a stock airbox. But if you're on a budget, it's a mod that's worth looking into
I'd like to give ChinoCharles credit for this one. It's his thread that gave me the idea to go ahead and make it happen.
Old 04-27-2014, 10:14 PM   #2
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
You should remove the carbon trap so you might make use of the additional available flow
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 04-28-2014, 10:55 AM   #3
detroiter
detroiter's Avatar
Thanks for the tip! Any effect on the MAF sensor though? So far I don't really see any change in MPGs or anything like that, just much louder (and nicer sounding!) under acceleration.
Old 04-28-2014, 11:18 AM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Removing that wont effect the MAF sensor.
-Derrick-
Old 04-28-2014, 11:30 AM   #5
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
I did this exact same thing when I first had my Yaris in 2007. Adds a nice sound.
Old 04-28-2014, 12:23 PM   #6
7:34pm
Drives: 07 Yaris
I'm bored and have the day off... so what size drill bit are we using, and we're drilling below the panel correct?
7:34pm is offline   Reply With Quote
Old 04-30-2014, 12:27 PM   #7
Thirty-Nine
Here's what I did.
http://www.subcompactculture.com/200...-my-yaris.html
Old 04-30-2014, 01:09 PM   #8
detroiter
detroiter's Avatar
Wow and I thought mine looked awesome lol. Good job!
Old 04-30-2014, 05:01 PM   #9
monchito18
monchito18's Avatar
Drives: Yaris sedan
Send a message via MSN to monchito18
How does it sound?
monchito18 is offline   Reply With Quote
Old 04-30-2014, 09:46 PM   #10
detroiter
detroiter's Avatar
Here's basically what I did...goes all the way around the lower portion of the intake box
Old 04-30-2014, 09:53 PM   #11
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
[QUOTE=detroiter;735854]Here's basically what I did...goes all the way around the lower portion of the intake box
that should make for some cool sound ...if u can post sound with intake running that would be fantastic .
One question ...what style air cone makes most sound open or closed end ?
Old 04-30-2014, 11:21 PM   #12
detroiter
detroiter's Avatar
At lower rpms with hard acceleration, it kind of reminds me of a boxer engine from a Subaru WRX. At higher rpm hard acceleration, reminds me of some Honda VTEC hah.
I'm using a high flow air filter as well.
Old 05-01-2014, 12:04 AM   #13
trunkout
4 years of P90X!
Drives: 09 Yaris Sedan
DOING THIS THIS WEEKEND!
trunkout is offline   Reply With Quote
Old 05-01-2014, 02:19 AM   #14
yariseggvvti
Drives: Yaris Hatchieback
I didnt drill any holes in the box. What I had done is took out the tube from the lower air cleaner box and put a K&N drop in filter. Sounds deep and once the VVTi active is screming.
yariseggvvti is offline   Reply With Quote
Old 05-01-2014, 05:30 AM   #15
detroiter
detroiter's Avatar
I've had the "elephant trunk" tube off for a long time...it does add a deeper sound. Once the holes are added, it's MUCH deeper than that.
Old 05-01-2014, 08:00 AM   #16
Silver Streak
Silver Streak's Avatar
Drives: 2010 Yaris sedan silver
Not to burst your bubble guys, but with summer right around the corner aren't you worried about all that under hood heat getting sucked into your airbox?
k&N Pannel air filter
Trd Exhaust
Trd Rear Sway Bar
Silver Streak is offline   Reply With Quote
Old 05-01-2014, 08:06 AM   #17
monchito18
monchito18's Avatar
Drives: Yaris sedan
I live in Puerto Rico and the car hasn't broken down and I don't have the tube.
Old 05-01-2014, 10:58 AM   #18
Silver Streak
Oh no, I wasn't saying it would break down. It will run fine, it's just that the cooler the air is entering your intake the better the car will perform.
Trd Exhaust
Trd Rear Sway Bar
Stock Injectors = Maybe? Big NO? maxthehax Forced Induction Forum 3 12-10-2012 05:29 PM
HELP need STOCK wiring harness for stock deck ya_RS Canada 0 09-26-2010 05:50 PM
Converting from Custom Wheels back to stock!!! daddz07 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-23-2010 08:45 PM
STOCK SEATS OUT OF HB / stock tires/rims mrrock Items for Sale by private party 19 08-19-2009 04:56 PM
lots of stock parts 2007 yaris h/b and some after market parts laszlo Items for Sale by private party 19 05-17-2009 04:19 PM
