#19 |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
I'm going to try uploading a video from the phone for an example.
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
#20 | |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
#21 |
4 years of P90X!
DONE! sounds better and seems to "lean burn" better too! Now I can't decide if my engine or exhaust is louder!
#22 |
![]() Drives: 2003 Echo Sedan, Silver Join Date: Jun 2014
Sorry to revive an old thread but saw this mod recently and used it on my car just today. Worked great and also removed the so-called "elephant trunk" intake pipe, sounds pretty good!
thx to OP. |
#23 |
![]() Drives: 2008 Yaris. Manual everything Join Date: Apr 2014
#24 |
![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
Did mine too and I did remove the neg from the battery for over a minute to reset the ECU, and since then I've noticed the car would reach higher RPM on strong acceleration before shifting gear (automatic transmission) that it did before. Looking at my fuel gauge (I filled up right after doing the mod), it seems I'm getting very poor mileage so far, but it could be due to many other factors, like the gas station auto-stop fuelling setting, the colder weather that just started (thus using the PTC heater more and blower fan more), etc. Perhaps the ECU needs more time to recalibrate with the air/fuel flow during fast acceleration. I would reach 4 000rpm easily from a dead stop before first first while before it wouldn't go beyond 3 500 rpm. Good/bad ?
#25 | |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
Sent from my G9208SS using Tapatalk |
#26 |
fwiw I have a short ram (modified my TRD CAI) and to aid in the heat soak I used 3" plastic heater ducting and cut a hole in my fog light cowling and ran the ducting up into the engine bay where it ends right at the air filter. The ducting it zip tied in 2 spot on the cowling and one spot in the engine bay
This won't do much when stopped but once moving air is forced into the ducting and flows out over the filter and essentially gets rid of heat soak. I don't have any dyno's to compare but it cost me $5 and about 15 mins to do. Also doesn't look too bad either.
| Stock Injectors = Maybe? Big NO? | maxthehax | Forced Induction Forum | 3 | 12-10-2012 05:29 PM |
| HELP need STOCK wiring harness for stock deck | ya_RS | Canada | 0 | 09-26-2010 05:50 PM |
| Converting from Custom Wheels back to stock!!! | daddz07 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 09-23-2010 08:45 PM |
| STOCK SEATS OUT OF HB / stock tires/rims | mrrock | Items for Sale by private party | 19 | 08-19-2009 04:56 PM |
| lots of stock parts 2007 yaris h/b and some after market parts | laszlo | Items for Sale by private party | 19 | 05-17-2009 04:19 PM |
