Old 05-09-2014, 10:59 AM   #1
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
Rear door inner panel removal.
That nice new car I posted a picture of recently now has a dent in one of the rear door skins! Some (censored) has obviously hit it with something in my absence.
I want to gain access to the door inside to see what could be involved and need to remove the trim panel (electric window so no crank handle).
I can only find reference to the Mk 2 Yaris online and this site.
Does anyone have instructions to remove or can confirm the following?
I suspect there is one screw under a small plastic cover disc behind the inside door handle. Would I be correct in that there are more hidden screws to be revealed when the window switch panel and it's power plug is removed? I would then guess it's just held on by push fit trim clips around the panel edges. Pull away, lift slightly off the window frame and disconnect the two cables from the door handle and locking lever?
Probably very similar to the Mk 2 method which I have done before.
mrpj is offline   Reply With Quote
Old 05-09-2014, 11:19 AM   #2
There is one in the door handle assembly and a second under the armrest cover. Then there are six of the panel clips that hold it on.
You don't have to disconnect the cables for the handle. Just pull out on the handle assembly to separate it from the door panel and then rotate it and slide it back through its mounting hole.
Old 05-10-2014, 04:13 AM   #3
mrpj
Many thanks, much appreciated.
30 seconds door panel removal (Liftback) W.A.S.P DIY / Maintenance / Service 62 10-17-2018 03:25 AM
-- Liftback Rear Speaker Removal? -- rarmogan In Car Entertainment + Electronics (audio / video / alarm) 2 09-25-2006 03:48 PM
