![]() Drives: 2007 Yaris RS Join Date: Oct 2012
C160 Helical LSD in a C50 transmission?
I have a 2007 Yaris with the C50 transmission, and I have found someone that is selling a C160 trans from an AE111 Corolla that might have the factory helical LSD.
As far as I can tell the C50 and C160 diffs should be interchangeable, am I correct? Are there any other issues I might run into if I try to install the C160 diff in my C50 trans? Just looking for some clarification before I buy anything, thanks in advance. |
2ZR swap. DO IT! Ask how!
I think BluevitzRS is the resident expert on the C160 -> C50 transplant, but I'll take a whack at it. It's definitely an 8-bolt differential, which is a good start, but without having one in hand to compare measurements, I can't confirm any further.
For the TRD LSD, the AE111 and the NCP91 use the same LSD (41301-AW004), so I would think it would work.
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
As long as the the diff in the C50 is 8 bolt, it should fit. You just need to swap the gear bolted to it and the speed drive gear if it's any different.
#6 | |
![]() Drives: Yaris Join Date: Sep 2021
Easiest way to get LSD in your Yaris
Yaris? I define easiest by taking out the current stock transmission, and installing a transmission that has LSD in it. What is there a transmission offered in the United States C 50 that had LSD already installed in it? If so, what model cars were they in and what part number would you look for to identify it? |
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
i installed a quaife qdf15e lsd in my c50, it is actually fairly straight forward to do once you understand how it all comes apart, as far as im aware, there are no factory c50, c52, c56 yaris transmissions that come with an lsd already from factory, always has been an add on
#8 | |
i bought mine from quaife website, took about a couple months to get, but couldnt be happier, youre in tuscon right? if you ever need help let me know i can show you how to install it and i made a tool for bearing preload adjustment
#10 | |
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| My 2010 yaris is on its 4th transmission!! Help please | Uzairlexus | DIY / Maintenance / Service | 12 | 07-16-2013 10:46 PM |
| Lsd for C51 gearbox | thefalls | Forced Induction Forum | 19 | 08-16-2012 08:51 AM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
| TRD Helical LSD | kngrsll | Items for Sale by private party | 18 | 04-27-2009 11:16 AM |
