![]() ![]() ![]() ![]() ![]() Drives: 2014 Yaris SE Join Date: Apr 2014
Low Fuel Warning Light
Could someone tell me if when starting the car, does the low fuel warning light momentarily illuminate? Mine does not, just want to see if that's normal. Every other car I've owned did.
The reason I ask is I filled up yesterday. I purposely waited until almost empty. The fuel gauge was one click above E and the “distance remaining” display was 5 miles. Low fuel warning light never went off. |
![]() ![]() ![]() ![]() Drives: 2013 Yaris Join Date: Oct 2011
It does not go off when we start the car. The low light comes on when it hits between 0 and 5 miles left and typically leaves 2 gallons left in the tank (at least mine does).
another good piece of info is if your averaging between 35 and 40 mpg, it should tick on after you've gone about 370 miles. But this is just the average for my car. :) I'm going to take a loose guestimate and say that if you filled up when it was at 5 miles left, you put in between 9.5 to 10 or so gallons. IIRC, we have a 11.5 gallon tank including the reserve. |
#3 | |
http://www.yarisworld.com/forums/sho...highlight=12.8 The most I've ever put in is 12.777 gallons. I ran out of gas as I was pulling into a station to fill up and filled until I could start to see gas in the neck. I think Toyota lists the 'capacity' as 11.1 gallons. Same for 3rd Gen? |
12.8 if you fill up to the neck.. like we usually say.. you can put about a gallon between "full" and the filler neck. lol
anyways.. AFAIK, there isn't a yellow low fuel warning light on the yaris, but the digital gauge will flash as a low fuel warning. Not sure about the 3rd gen since the 3rd gen gets an analog gauge.. According to specs, it has a low fuel warning... |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
Hmmmm......my 2009 doesn't flash and i ran dry with two bars still.
the last bar should flash.
if it doesn't go below 2 bars, your sensor might be out of place or something. |
Sensor or fuel sending unit?
Nevermind got it. I'll open up the unit and take pictures to post here for others.
#9 | |
I know every car is like this but I wish manufacturers would trust me with accurate readings. When the fuel gauge says E I want it empty and when the speedo says 60 I want it to really be 60, not 58. My speedo seems to be reading about 2 MPH above actual as per my GPS. That's not too bad, I've seen cars showing 5 MPH or more. |
Great thread. Posts from Mr. Miles and NYC-SE are allowing me insight into living with the warning light, the trip 'computer', and the 'bar-less' gas gauge through mujltiple tanks (I had a 3rd Gen rental for 3 days, but used less than 1 tank).
mr miles, will the point where 'distance remaining' first hits 0 (zero) always be at the same fuel level point? In other words (for the sake of comparison), if I happened to be right next to a gas station each time the 'distance remaining' first hits 0 (zero), and I always fill to the same point where I first see gas in the neck, would each fill up essentially be the same...not re cost, but re quantity ? I'm trying to determine if once the distance remaining first hits zero...at that moment....will the quantity of gas remaining until complete empty/out of gas essentially be the same each time. |
That's something I've been trying to figure out, actually. I've tried driving it hard or in lower gears to significantly lower mileage to try and fool the computer a bit. so far it seems fairly accurate that the light comes on with damn near the same amount of fuel remaining. I know in my car once the fuel light comes on, the fuel gauge needle will drop below the "E" line with what appears the be the same distance between and of the other lines on the gauge and then wont go down anymore.
I can personally go about 75 miles once the distance remaining hits 0. Then I get a little uncomfortable. That was almost a 12 gallon fuel up day lol. my record is 480ish miles on one tank. for second gen owners - our third gens have a needle style fuel gauge, Toyota did away with the digital readout gauge you guys have, so we get a little "HOLY CRAP MAN YOU NEED GAS" light :) where as you just get an annoying blinking light that never reads correctly. the only reason I've been able to figure any of this out is because I'm lucky enough that if I do nothing but drive to and from work, there's almost always a gas stating within eye sight of me when my light comes on. it's been pretty fun to do it. These cars are like clockwork. (and I try to drive it in a consistent manner lol) |
#12 | |
Definetly a possibility. I will do a visual check of the two when I get home and let you know!
#14 | |
#15 | |
#16 |
Ronald
Drives: 2007 Yaris Hatchback 5 Speed Join Date: Jul 2014
I just bought my Yaris I got 370 miles before the bottom bar started blinking...
What i would like to know is about how far can you go with it blinking .....2007 Yaris |
#17 | |
Only Happy When it Rains
Quite a few people won't ever let it get below 2 bars left, because there have been a few cases of two bars left then all of a sudden running out of gas. Really weird. In general I make stopping at the gas station a priority when it starts blinking, and that works for me.
Colin Chapman disciple |
#18 | |
| Fuel Light | GTBaker | Third Gen Yaris General Discussion | 11 | 12-04-2012 08:22 PM |
| Original tail light without rear fog light for Yaris 3dr 2009-2011 | Ot_tO | Cosmetic Modifications (Exterior/Interior) | 9 | 08-07-2012 04:27 PM |
| "5 Driving Myths That Cost You Money" | PETERPOOP | Fuel Economy Forum | 10 | 05-24-2011 10:20 PM |
| Last Fuel Bar | andaconda | Fuel Economy Forum | 37 | 04-29-2009 02:35 PM |
