![]() Drives: 2004 echo RS Join Date: Jul 2014
Will these fit?
I found a smoking deal on some tires and rims todays in the local adds, and I was wondering if they would fit or if they would rub on my 04 RS.
Tire Size are 205/45/16 4X100 My car is not lowered. Thanks
Drives: Toyota Yaris AT S limited 2008 Join Date: Jul 2013
according to my personal experience it will fit, but there will be some gap between the tire and fender though.
Sent from my iPhone using Tapatalk |
Would this be because the car is not lowered? But would be fixed if it was?
Thanks again |
what gap? the gap will be the same with this 16''... about 7mm larger in diameter, and 1.3% variance on the speed. I'd say go for it as long as the offset is between 32ish and 45 and rims no larger than 7''
http://www.1010tires.com/Tools/Tire-...5R16/205-45R16 |
You don't say the size of the wheel or the offset. Those are important details. In general, without the car lowered you should be just fine with that. I ran 205/50/16 and had minimal rubbing on a lowered car.
![]() Drives: Yaris Sedan YRS Join Date: Mar 2013
16x7 4x100 offset 42 wrap on 205/45/16 and I might use Df210? With an inch lifter at the back will there be a rub on a Yaris sedan?
Drives: Yaris Join Date: Jul 2014
Don't want to start a new topic. Just a quick question: will 185/65/16 wheels fit on stock 2008 yaris hatchback? Thanks.
That's a tire size, and it's a little tall, but yes
#9 | |
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 06:02 PM |
| Test drove Rio5, Fit, and Yaris all today | kmf123kmf | New YARIS Purchase Forum | 16 | 10-02-2009 08:48 PM |
| test fit 06-07 Yaris 4 door fog light | winson | California | 15 | 01-13-2009 09:25 PM |
| I test drove a Yaris, Versa and FIT | CanadaCraig | New YARIS Purchase Forum | 41 | 11-29-2008 10:18 PM |
| Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd | Bounty Hunter | General Yaris / Vitz Discussion | 7 | 07-11-2007 08:40 AM |
