Old 06-11-2014, 11:08 PM   #19
Astroman
Modded Moderator
Astroman's Avatar
I looked at his remote start guide and it did reference the pink wire but it was labeled ignition 2. Guess I'll just use the 12v accessory port for now. I'm up to 3 devices I use all the time and it'll be nice to write some of that in.
Old 06-19-2014, 08:14 PM   #20
ReedH
Drives: 2013 Toyota Yaris Hybrid
Can you tap it from the back of the Radio/entertainment system? I wired a radar detector into that on my old car.
I've seen Male/Female splice connectors that allow you to do it without even cutting stock wires.
ReedH is offline   Reply With Quote
Old 06-29-2014, 12:45 PM   #21
kaymm
kaymm's Avatar
Drives: Yaris Liftback 3dr (Silver)
Hi,
I already have a dashcam facing the front powered via lighter adapter. Instead of starting another thread, I hope I can hitch on to this one :)
I want to put a dashcam mounted under the top rear brake light that will record what is behind me as well. Where can I tap power from in the back of the car that has 12v when engine is on? I'm hoping I can tap power from somewhere near the left backup light area.
07 Yaris LB 3dr
Silver Mica
5sp manual shift
kaymm is offline   Reply With Quote
Old 06-29-2014, 09:19 PM   #22
rytis
Drives: 2010 Yaris Hatchback 5dr
Hey,
I had the same idea. But will be sticking to just the front camera. I saw somewhere that there's no source like that in the back. You'll have to run it from somewhere in the front.
rytis is offline   Reply With Quote
Old 06-30-2014, 12:58 AM   #23
MoneyT8
Drives: White Yaris Sedan
I use the cigarette lighter socket for my dashcam. Quick question where did you mount your front facing dashcam? Did you mount it on the black dotted lines right behind the rearview mirror? If so how did you do it as it is close to impossible to do so with the suction cup not sticking.
MoneyT8 is offline   Reply With Quote
Old 06-30-2014, 11:52 AM   #24
kaymm
kaymm's Avatar
Hi, my dashcam has a mount that sticks on the window. It sticks on the dotted area of the window even. It has some 3M tape. It's been on my car for 3 years and never fell off. If you have a suction type of mount, you can buy these discs that have 3M tape on one side and a smooth surface on the other and it'll let you suction to. My old dash cam had a suction cup mount and I used these discs. Even with it, I hate suction cup mounts, they fall off every now and then when you're driving, annoying. Double sided tape is the way to go. Google "suction cup discs"
07 Yaris LB 3dr
Silver Mica
5sp manual shift
Old 06-30-2014, 12:16 PM   #25
kaymm
kaymm's Avatar
Anyone know of the closest constant 12v near the rear lights? I'm really trying to avoid pulling a long wire to the front console.
07 Yaris LB 3dr
Silver Mica
5sp manual shift
Old 06-30-2014, 05:44 PM   #26
rytis
This is how I mount my Mini 0801 (it comes with the 3M tape)
Old 07-01-2014, 12:24 AM   #27
kaymm
kaymm's Avatar
Originally Posted by rytis View Post
Hey,
I ended up getting a very long extension and tapping into a fusebox to get a 12v source when ignition is on. It wasn't too bad, I ran it on the left side and into the trunk
07 Yaris LB 3dr
Silver Mica
5sp manual shift
Old 07-15-2014, 10:04 PM   #28
ReedH
I try to avoid taping things with fuse taps. It's just personal preference but it makes me a bit uncomfortable. I'm running my radar detector with one of these:
http://www.autoharnesshouse.com/76297.html
It's fused and uses the power to the headunit and just leeches off of it.(clean and no wire splicing)
Dual lens car dash video camera Red Horse In Car Entertainment + Electronics (audio / video / alarm) 8 05-16-2014 05:42 AM
DIY Camera Mount -- No Cost Version KCALB SIRAY DIY / Maintenance / Service 20 06-08-2009 03:12 PM
