![]() Drives: 2007 Toyota Yaris Join Date: Mar 2012
2010 Headgasket
I owned a 2007 yaris sedan until 2012 when it was totaled in wreck.
I then bought a 2010 yaris sedan, and with about 60K miles I need a new headgasket. I'm debating...fix it ($1650) OR get a newer model. Thoughts? Ideas? Suggestions? Commiserations? |
#2 | |
The fix is not that expensive lot cheaper than a newer car but if so go with 2012 up. |
For way less than $1650 (typically $500 or less) you can purchase a junkyard engine (with a warranty). Swapping the engine is actually an easier job than swapping a head gasket.
I agree with CtScott
After I posted this and started writing the numbers down I went through my paperwork, the car is still under warranty (extended warranty, yay). The dealership wants to look at it first though to decide if its 'covered' or not...
Should be ...power train warranty ...for sure ,that's awesome !
| Increased ground clearance between 2008 and 2010 Sedan | unclenefeesa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 01-17-2013 05:49 AM |
| Bought A Used 2010 Yaris Sedan & Customized! | us13doolittle | New YARIS Purchase Forum | 8 | 10-14-2012 05:16 AM |
| GO FOR IT ? Trade 2010 3 door ( W/oil leaking head gasket ) for 2010 sedan | Hershey | New YARIS Purchase Forum | 9 | 10-10-2010 01:06 AM |
| Does the 2010 5-door/5-speed actually exist? | adrew | New YARIS Purchase Forum | 26 | 12-14-2009 06:57 PM |
