Old 07-25-2014, 12:48 AM   #1
silver*yaris
Drives: 2008 Toyota Yaris
Water pump
Hello everyone. I own a 2008 Toyota Yaris that has about 35,000 (i don't drive much actually). I recently had my regular oil change at the Toyota service place, where i have done all my car's maintenance services. They told me the water pump had began to leak and said it should be replaced soon. The cost would be around $500. I have never had any problems with the car, I have kept up with all its maintenance at the dealership and this is the first time that something defective comes up. I find it very expensive and also wonder if a car with this low mileage should have a problem like this. I am calling other places to see what they can offer but I'd appreciate any thoughts or suggestions from anyone here. Thanks!
silver*yaris is offline   Reply With Quote
Old 07-25-2014, 12:54 AM   #2
silver*yaris
Water pump
Old 07-25-2014, 12:57 AM   #3
sex
sex's Avatar
Drives: 09 5DR
were you shown evidence of the leak? search the forums here for pictures of what a failing pump looks like; theres a pink streak on the underside of the hood
sex is offline   Reply With Quote
Old 07-25-2014, 12:59 AM   #4
silver*yaris
no, I was not shown any evidence. will search for that! Thanks!
Old 07-25-2014, 01:01 AM   #5
kou
Drives: 08 lb
The waterpump failing early is nothing new in the yaris community. $500 is an insane price water pumps can be bought for less than $50 and the coolant $25 and maybe an 1.5hr labour
Old 07-25-2014, 01:13 AM   #6
silver*yaris
Good to know it's nothing new. I knew it was too much $$... yikes. Thank you, kou!
Old 07-25-2014, 03:14 AM   #7
john21031
Drives: '10 Fit Sport MT and 2012 Fit
It's supposedly one common items that failes fairly consistently on a Yaris. The part itself is only about 130$ from the dealer, and maybe 50$ from Autozone.
It should be possible to do the repair for someone with average amateur skills in repair. Plenty of do it yourself guides.
john21031 is offline   Reply With Quote
Old 07-25-2014, 07:09 AM   #8
BLH
Drives: 2007 Yaris Sedan
My 2007s water pump failed at around 13,000 miles.
Had the pink streak across the inside hood.
Was a warranty repair for me.
BLH is offline   Reply With Quote
Old 07-25-2014, 07:14 AM   #9
bronsin
bronsin's Avatar
Common problem.
Get a few estimates from other shops.
Good luck and tell us what happens!
PS dont even THINK about giving up on the Yaris because of this problem! It has many more trouble free miles in it.
PPS If you ARE going to sell it PM me first!
bronsin is online now   Reply With Quote
Old 07-25-2014, 03:34 PM   #10
nookandcrannycar
....then me (if bronsin changes his mind ), if your Yaris has a manual transmission.
Old 07-25-2014, 06:05 PM   #11
Here's a link to my DIY in case you feel like tackling it yourself.
http://microimageonline.com/forums/s...1NZ&highlight=
Old 07-25-2014, 06:09 PM   #12
Tags
water pump, yaris 2008
water pump change 2sz-fe finnpoulsen DIY / Maintenance / Service 5 03-25-2020 11:20 AM
drive belt replacement and/or water pump replacement sociolog DIY / Maintenance / Service 9 02-10-2014 01:33 PM
Water Pump gave up on me finally Vioz DIY / Maintenance / Service 4 07-31-2011 07:08 PM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 10:14 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 10:26 AM
