#181 | |
#182 |
![]() Drives: No longer own a Yaris Join Date: Jul 2014
"Ahhhh" said the blind man as he saw his wooden leg.
Thank you for that, finally someone who is making some sense!
I might be picking up some Tien Springs and then try one of these sway bars. I just hope it doesn’t lower the car too much, I drive in Seattle a lot and the roads are some of the worst in the country due to pot holes and other obstacles. I am also dying to get cruise control for my car but have not put to much time into getting the parts, I wish there was just a kit I could by all-in-one. |
#183 | |
#184 |
The Tein springs are the lowest off the shelf springs. Expect a 2" drop if not slightly more.
#185 |
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
Well that was quick and easy, and comparably painless.
#186 |
Where does one buy the Ultra Racing 19mm sway bar? The Micro Image website lists it at $280 (way too high?!) and it's out of stock.
#187 |
Minimalist
Drives: 07 silver sedan Join Date: Jun 2014
I'd sell you mine, if you weren't practically on the other end of the continent.
#188 | |
D.
. CLA 250, 4MATIC |
#189 |
![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
Does anyone know if they still make the rear sway bar 22mm for a 2005 echo hatchback?
#190 |
Drives: 2007 Yaris Join Date: Jul 2019
Thanks to everyone who contributes to this forum!
As a new Yaris owner, it is quickly becoming a top resource to learn more about my vehicle. From the info provided here, I decided my first modification will be the sway bar. It is scheduled to arrives this afternoon! Can't wait to feel the difference. Thanks |
#191 | |
![]() ![]() Drives: Toyota Vios Join Date: Feb 2013
#192 |
![]() Drives: 2012 Sedan Join Date: Nov 2018
#193 |
In theory your car is stiffer and some of the forces that one strut tower normally handles are transferred to the other strut tower. More rigidity.
I can imagine this can make a difference for big cars that are driven aggresively on bad roads. I am not sure if that makes sense for my 64kW Yaris but never tried to drive with and without to get any feel of it. Anyway, with almost 200 thousand kilometers it would be a lot better just to replace original shocks. :D |
#194 | |
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
I'm a hermit named Lee |
#195 |
![]() Drives: Yaris Join Date: Dec 2018
Bit late to the party but living in a rust prone area, will 44 ft lbs torque be enough with pretty weathered shock bolt and nut or should I loctite the shock nut on? Took quite a bit of work to get it off.
#196 |
replace the bolt dont locktight
#197 |
We are probably in the same rust belt. Looking at pics is tough but I think those threads are fine. Wire brush them a bit to get the gunk off, apply a little grease and spin the nut up and down the bolt a few times. Degrease the bolt and torque down the nut. 44 ft lbs is not really a great deal of torque and bolt will handle it just fine.
#198 | |
| Rear Sway Bar Instructions - Additional Pics | SeaYa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-26-2009 01:05 PM |
| TRD rear sway bar...street or race setting? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 02-08-2009 02:26 AM |
| TRD Rear Sway Bar Install ?? | bikegerm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 12-26-2008 01:46 AM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-05-2008 11:37 PM |
| DIY - TRD rear sway bar | kurokoma-kun | DIY / Maintenance / Service | 0 | 10-20-2008 01:21 PM |
