2ZR swap. DO IT! Ask how!
Drive shaft snap ring - OK to re-use?
Looks like I somehow got the wrong inner snap ring for the driveshafts, and I don't really have time to wait until tomorrow to order new ones. The old snap rings are still there, how bad is it to re-use them?
I think it is fine to do so. Just make sure the opening points down when you insert it.
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
^ what he said.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
Crap. I didn't check the orientation. Too dark under there when I popped them in. That said, the gearbox is in and seems to be running just fine. Too bad I didn't put match marks on the steering column before disconnecting it...
I think you will be fine!
| I got $50 to test drive | Cutie Pie #2 | Off-topic / Other Cars / Everything else Discussions | 6 | 02-23-2009 09:51 AM |
| Add another hard drive to a laptop? | CompanyXPaladin | Off-topic / Other Cars / Everything else Discussions | 4 | 11-23-2008 12:18 PM |
| Longest Test Drive? | lostmind | General Yaris / Vitz Discussion | 4 | 05-31-2007 05:20 PM |
| Floor Mats 4 Aussie Yaris (right hand drive) wanted! | YesHapiness | Cosmetic Modifications (Exterior/Interior) | 6 | 02-12-2007 07:29 AM |
| 07 yaris liftback and 06 xa test drive | extenny | General Yaris / Vitz Discussion | 12 | 05-31-2006 11:56 AM |
