Old 09-23-2014, 07:11 AM   #19
IllusionX
Drives: 07 Yaris Sedan Aero
Remove the steering wheel column cover?
Old 09-23-2014, 09:09 AM   #20
Originally Posted by jambo101 View Post
I tried the locksmiths suggestion and it didnt work as there was no place that i could put the factory key that would make a regular $2 key start the car.
It would have to be in very close proximity to the coil that surrounds the ignition switch. As mentioned above, removing the lower steering column and then taping the key to the side of the ignition switch assembly would work best.
Old 09-23-2014, 10:50 AM   #21
bronsin
bronsin's Avatar
Sounds like maybe an aftermarket device to defeat the system?
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 07:32 PM
Help needed! RE: Spare Smart Key zenyvitz DIY / Maintenance / Service 9 09-28-2014 11:29 AM
