Old 09-26-2014, 09:41 PM   #1
maui
Drives: 2008 Yaris hatchback in white
2007 sedan front brakes job questions
at 126K replacing the original rotors and pads
went with Bosch Quiet Cast rotors and Akebono ceramic pads
from Amazon who offer free shipping, a real plus for Hawaii!
original pads still have alot of meat on them and the sliders are likely having some restriction
My intention is to use the original sliders, cleaned up and lubed with Napa Sil Glide grease, unless they look really worn once dis assembled.
Would have replaced the sliders but no one has them locally, and the shipping hassle... Am I making a mistake here?
Thanks
maui is offline   Reply With Quote
Old 09-26-2014, 10:22 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
If ur talking about the caliper sliding pins ,just clean and lube/grease ..I use silicone grease ( less is more ) and silicone spray over that works amazing and last long time also make sure ur fitting kit is clean remove from caliper bracket and clean well under use antsize and and put all back together , for pads I use silicone grease too .
Make sure pins/ sliders are not rust pitted and rubber boots good shape.
sent from my S4 on Mars
Old 09-27-2014, 07:43 PM   #3
maui
torque specs for wheels, calipers
Thanks Wolfman, the pads arrived today so I should be good to go.
Is it really important to use a torque wrench for re-assembly?
If so will have to borrow one. Someone probably posted torque specs
but have not yet found that info... Anyone?
Old 09-27-2014, 09:07 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Yes u could use a torque tool but honestly just tighten nice and snug for pin bolts as for caliper bracket they should be tight as for torque spec I would have to look it up.
Old 09-27-2014, 09:29 PM   #5
Caliper mounting bolts are 25 ft lb.
Old 09-27-2014, 09:39 PM   #6
fourbangingfun
fourbangingfun's Avatar
I wouldn't sweat the torque rating for caliper bolts. A nice solid, snug level should do the trick. We have done it this way for many years in my house and never had any problems.
Now we did use the factory torque specs for big bolts like the strut bolts when we installed lowering springs etc..
fourbangingfun is offline   Reply With Quote
Old 09-28-2014, 10:18 AM   #7
^+1 My torque wrench doesn't get used very often, but I've been working on cars for over 30 years, so I can typically get within a couple pounds of spec by feel.
Old 09-28-2014, 11:23 AM   #8
For caliper bolts, and many others that I know need to be good and tight, I just give them the old "double grunt".
Old 09-28-2014, 11:33 AM   #9
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
U mean the bracket bolts 17mm one , 14mm caliper a good snug those u can snap if not carful .
Old 09-28-2014, 11:35 AM   #10
Originally Posted by Exiwolfman View Post
U mean the bracket bolts 17mm one , 14mm caliper a good snap those u can snup if not carful .
Bracket. The sliders are just snug.
Old 09-28-2014, 11:36 AM   #11
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
+1 ^
Old 09-28-2014, 08:18 PM   #12
maui
thanks guys, will give it a go using hand tools, and feel
Need to know if shocks are same Sedan and Hatchback 2007 Ben_davis DIY / Maintenance / Service 2 11-29-2013 08:23 PM
2007 Sedan HU, Amp, Speaker install Crackerballer In Car Entertainment + Electronics (audio / video / alarm) 15 11-14-2011 07:47 PM
My Review of My Yaris Sedan 2007 David81 New YARIS Purchase Forum 6 09-10-2006 12:48 AM
