![]() ![]() ![]() Join Date: Sep 2014
2015 yaris, rear view camera
I Will tray to install this Chinase Rear view camera (picture 1)
I try to remove this plastic, but i can't.(picture 2) I found this connector, i think this is for rear view camera |
I found This
And this
Ctscott do you know the part number for this 24 pin connector
No. The camera is not documented in the US wiring diagrams, so that connector is not even shown.
OK - Found the connector in Europe. It is part of a the installation kit for the camera: PZ457-B0140-00 (which includes the harness and pins and the connector.
The OEM camera is: PZ473-B0140-00
Thank you ctscott, in Do you have the link?...
I found pz457-b0140-00, around 60 usd, this is the connector?
http://partsale.eu/spare-parts/view/...14000-74818965 |
But no the oem camera
Doing a search for the camera part number shows a couple of European sites with it. Try emailing the folks at the link below, as I have always had good luck ordering European Yaris parts from them:
http://genuineserviceparts.com/
CTScott, do you think, this will work
http://www.ebay.com/itm/Toyota-Displ...113b80&vxp=mtr or this http://www.ebay.com/itm/OEM-BACK-UP-...64b626&vxp=mtr |
The second would not be of use unless you were using an aftermarket radio. The first may work, but I am not sure, as the bare camera (86790-0d010) is a unique part number to the Yaris, where many of the other vehicles with cameras share a common part number.
i will buy
http://www.ebay.com/itm/OEM-BACK-UP-...64b626&vxp=mtr thank you for your help i will pay the same price for harness, and the shipping . |
#14 | |
![]() ![]() ![]() Drives: yaris le Join Date: Sep 2014
can't you just splice the wire to reverse light signal ? Thanks |
The camera I bought in alibaba.com, 8 months ago
Now i waiting a cable video that bought with autoharnesshouse.com |
I got the cable from autoharnesshouse.com and Now i will try to connect.
I connected to the head unit. I run the cable camera, And + wire, And - wire. To the front of the car. Brian from autoharnesshouse.com, tell me that i need to use the red wire to power the camera And negative wire i was connected to a screws under the dash Now i need to connect to reverse wire. I asked in other post.. And CTScott help me. But i can't found how to connect. |
one question.
i will take the + wire, from reverse light, i will run from back to front. one pin on the harness, is the reverse light trigger, then, i will connect .. + wire from reverse light, + red wire from harness and +wire from pin trigger? this is correct? Last edited by Eduardo_mty; 11-10-2014 at 12:46 PM. |
pictures
| Do you like the 2012 restyle? | hitmoninfinity | Third Gen Yaris General Discussion | 106 | 04-14-2016 08:08 PM |
