![]() ![]() Join Date: Aug 2014
Driver's door misaligned.
Notice today that my driver's side door is misaligned. There is no way that it has always been like this. Is this something the dealer will fix for free under warranty?
Driver's door.
![]() Passenger's door
You can ask, but it may be due to the door having been opened too far.
I never open my door very far. Just don't have that kind of room at my house. So it can't be from that.
It only sticks out in that one spot. I wounder if it could just be that bumper piece in that area. Maybe sanding it down would fix it.
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
I would try under the warranty unless you can find some damage.
Open the door look at the hinges, see if they have moved. Also check the lock for movement. Check around the inside of the door frame for damage from being closed on the seat belt, doubtful but could happen. The doors are pretty massive, would be tough to tweak. Just my two cents. Norton |
It's probably just the camera angle and the shape of the door but the lines on that passenger door don't look to be very consistent/equal.
Passenger door looks perfect in person.
| LED Color Change Problems w Drivers Door | jeeper5usa | DIY / Maintenance / Service | 2 | 09-15-2012 11:32 AM |
| Help! Replacing driver's side mirror | temps2020 | DIY / Maintenance / Service | 3 | 11-11-2010 11:08 AM |
| Retesting Drivers? | chrisj | Off-topic / Other Cars / Everything else Discussions | 7 | 10-23-2010 08:56 AM |
| Drill hole in Driver's glovebox? | Revsson | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 07-05-2010 05:26 PM |
| And the worst drivers in America live in..... | KCALB SIRAY | Off-topic / Other Cars / Everything else Discussions | 12 | 05-22-2009 08:55 PM |
