Old 11-17-2014, 12:45 PM   #1
Dubdoc
Drives: 2009 Yaris sedan
Odd exhaust issue
I recently bought a 2009 Yaris sedan which was well optioned and well cared for. About 2 months later, it has developed an exhaust noise. The muffler shop says it's a cracked exhaust manifold. Is this a common problem. The shop says they've never seen it on a Toyota before.
Dubdoc is offline   Reply With Quote
Old 11-17-2014, 12:48 PM   #2
Cracked ones are very uncommon on our cars, as the OEM manifold is welded tubing, rather than being cast. My bet is that rather than a crack that it is the gasket between the manifold and the mid pipe. That soft metal gasket is a far more common failure point.
Old 11-17-2014, 01:37 PM   #3
Dubdoc
Cool. I knew the Corolla was tubing but just assumed this one was cast since the tech mentioned "cracking".
Typical muffler shop incompetence.
Old 11-17-2014, 01:51 PM   #4
CoryM
Drives: 2009 5-door, 5-speed
It's much less common with steel manifolds, but can still happen. I'm with CTScott though, probably a gasket. If it's a primary exhaust leak (the tubes coming from each port, before the collector) it will sound more like a * tack tack tack* noise. Especially when cold starting. If it's just a steady, louder noise, it's after the collector.
Cheers.
Old 11-17-2014, 02:09 PM   #5
BobTheYaris
BobTheYaris's Avatar
Drives: '08 Yaris HB 2 dr
Would it sound like a sorta vacuum leak under load while driving. Ive had something similar but cant find the source
Sent from my iPod touch using Tapatalk
BobTheYaris is offline   Reply With Quote
Old 11-17-2014, 05:53 PM   #6
CoryM
I would guess you're just hearing the air going through the airbox or past the throttle body. There is a normal air noise in the Yaris under certain conditions.
Cheers
Old 11-17-2014, 06:18 PM   #7
shepd
Drives: 2007 Yaris 5 door RS
A broken exhaust manifold / header will make a ticking noise, and you may smell exhaust in the engine bay. Although you may get that (but louder) if the donut is broken.
Odd throttle issue mr_miles DIY / Maintenance / Service 21 11-01-2014 10:20 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 09:02 AM
Enkei's and Dunlops + Medalion Touring Exhaust 2manywheels Items for Sale by private party 40 04-04-2011 06:01 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 10:23 PM
