Old 11-26-2014, 10:58 AM   #1
bentjazz
Drives: 2009 Yaris--3dr MT
Another reason to love our simple low tech Yaris....
Here is another reason to love our simple, low tech Yaris, folks.
http://abcnews.go.com/Technology/wir...react-27132494
bentjazz is offline   Reply With Quote
Old 11-26-2014, 11:14 AM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Why do you think a Yaris is not vulnerable? We've got drive by wire throttles(aka computer controlled) ECU that run everything, and an ECM like every other car on the road. The Yaris is just as vulnerable.
Colin Chapman disciple
Old 11-26-2014, 11:16 AM   #3
The Yaris has no connections to the outside world though, so any hacking has to be done by making a physical connection to the CAN bus.
Old 11-29-2014, 12:25 PM   #4
Jcp123
Drives: '00 Echo
Not sure I'd call the Yaris low-tech...only by comparison I suppose.
Jcp123 is offline   Reply With Quote
Old 11-29-2014, 01:39 PM   #5
Gogogordy
Drives: Miss my Yaris, love my Jeep jk
Agree....
Far from low tech, only lowly accessorized (in comparison) with lotsa electronic doo-daddery.
I'm the Prez at my house...in fact I cruise around in YarForce One!
When I'm not driving my Yaris, I'm doing this:
http://gogogordy1.wix.com/scooter-aficionado
Gogogordy is offline   Reply With Quote
Old 12-05-2014, 01:52 PM   #6
Jcp123
Drives: '00 Echo
Yep, that's kinda what I was getting at :D
Old 12-05-2014, 06:11 PM   #7
Gogogordy
They still have more computing power than the first space shuttle did!
Old 12-05-2014, 07:32 PM   #8
Jcp123
Drives: '00 Echo
I'm old-school. Variable valve timing meant your chain had slipped a tooth and fuel injection was when you sprayed ether down your 4-bbl carb :D
Old 12-07-2014, 05:21 PM   #9
shepd
Drives: 2007 Yaris 5 door RS
Weren't some of the Yarii equipped with BlueTooth radios? I doubt the radios are connected to CANbus but they could at least frustrate you by turning your radio up/off/whatever. LOL.
These cars are also drive by wire, so they are remotely hackable in a sense--enough interference and the accelerator wouldn't work properly (then again, in any car with a PCM, the engine is likely to stop running too).
Old 12-26-2014, 04:05 PM   #10
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
The radios have no connection to the bus at all, even those with navigation.
I have investigated this topic, it might be possible to control the throttle angle via the bus, however, I have not seen any way to reconstruct an active test from Techstream in order to do so, because there isn't any (at least on my 2009 TMMF 1KR-FE MT).
You would have to get the source code,reverse engineer the ECU or spend years on brute-force tests.
Most active tests are unreachable if the ignition is turned off.
The only ones I have found to be independent of this are the dome light and the power relay which gives power to the power windows - but only the non-automatics, which applies to the front passenger side on mine.
However, it is still impossible to operate the windows this way - you have to be inside the car or have a door opened, so there is no use of it for "unauthorized entrance" at all.
Those active tests work via OBD commands, namely CAN IDs 750hex and 758hex iirc.
Keep in mind, that you have to get access to the bus wires of the car to do anything of that kind, another possibility would be connecting to an OBD interface - most of them don't have a switch and even if, most drivers won't operate them (including me).
I don't remember whether ignition had to be turned on to operate the door locks and I don't remember the details of my research about "can you get unauthorized access to the car?" and "can you simply misuse the electric system to set the car on fire?", but I consider both things improbable enough to ignore them, also because an immobilizer is mandatory here.
Why I investigated the second question?
At least in the first European Mk1, the power for the dome light ran across the cluster's PCB, but was only secured with a fuse of 15A or so - in any case, way too much current to make sense.
A friend of mine's Mk1 almost burned down when the dome light got a short, so I wanted to see whether the Mk2 has huge fails of that kind inside.
OK, the wires are quite thin, but up to now (!), I did not find any bigger issues.
I drive, therefore I am.
dj92 is offline   Reply With Quote
Old 12-26-2014, 05:20 PM   #11
nookandcrannycar
Brings back memories of using a spray on the aftermarket Carter AFB 4-barrell on the Firebird that was mine to drive until I saved up enough money (at 17) to buy my own car.
Some elusive Yaris tech specs Steven1541 DIY / Maintenance / Service 2 02-11-2014 06:01 PM
Coolant sitting low (3 door 2007 Yaris) douchenozzle DIY / Maintenance / Service 6 01-31-2014 12:03 PM
Yaris tech yaris9876 DIY / Maintenance / Service 0 12-23-2013 02:43 PM
