Old 10-11-2010, 09:35 AM   #1
magilla
Drives: yaris hatch back
steering wheel and front seat
does any one know if theres any porblem with swaping the steering wheel and can u swap the front seats easily? i know theres the passenger air bag sensor ?
magilla is offline   Reply With Quote
Old 10-11-2010, 11:31 AM   #2
Driver steering wheel has an airbag in it. You will lose that with an aftermarket wheel.
Both seats have airbag sensors. You can retain functionality by wiring in a small circuit, otherwise, your airbag system will probably not function correctly.
Old 10-11-2010, 09:10 PM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I know in my Echo, only the passenger seat had the airbag sensor. The driver's seat only had a seatbelt sensor.
Old 10-12-2010, 12:05 PM   #4
magilla
howed u get around sensor?
Old 10-13-2010, 11:58 PM   #5
magilla
how do u bypass the air bag sensor
Old 10-14-2010, 12:07 AM   #6
The driver's side one just detects the position of the seat and can be moved over to a replacement seat. The passenger side has the passenger occupancy ECU, which weighs the contents of the seat using 4 load cells that are mounted within the seat frame. I developed and sell a module that plugs into the passenger occupancy ECU and responds to the LIN Bus messages from the ECU, pretending to be the 4 sensors. The module has a switch that allows you to choose to have the airbag active or off (where it either tells the ECU that the seat is empty or is occupied by a 150 lb person).
Old 10-14-2010, 02:03 AM   #7
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
first of all what year is your yaris and what are you planning to do?
yours is a european make correct? try go to your dealer and find out if yours is equipted with airbag occupant sensor first
you are vague in your actions
are you trying to find out if you can put a aftermarket steering wheel?what kind were you thinging of buying
replacing with another yaris wheel? same goes with the seat, are you planning to replace with racing seats?
OTA'sTOY is offline   Reply With Quote
Old 10-14-2010, 11:14 AM   #8
magilla
grant f1 steering wheel and zx seats there all going in 07 yaris hatchy
Old 10-14-2010, 11:15 AM   #9
magilla
how much is the switch controler?
Old 10-14-2010, 11:28 AM   #10
$55 shipped.
If you want to read a bit about what went into developing it, check out this thread: http://www.yarisworld.com/forums/showthread.php?t=20730
This is what it looks like:
Old 10-19-2010, 02:53 PM   #11
3cyltrbo
don't the seats in the 09+ have side airbags IN the seats????
here in the land of the Igloos (Canada) our Yaris's now come with 6 airbags (all models) - doesn't that put the side ones in the seats (then 2 more on the dash and 2 in the roof) ???
Will
3cyltrbo is offline   Reply With Quote
Old 10-19-2010, 04:11 PM   #12
Will
Yes, the 09+ have the side airbags in the seats. When replacing the seats, you simply connect a 3 ohm resistor in place of the seat squib to keep the SRS ECU happy.
Old 12-14-2014, 07:36 PM   #13
WorkTL
WorkTL's Avatar
Drives: 2013 Yaris LE
Besides the passenger side ocs bypass for a 12+, what else would I need to at least install a drivers side Sparco in a 2013 and not have any lights pop up?
WorkTL is offline   Reply With Quote
Old 12-14-2014, 09:50 PM   #14
The driver's side is easy - Just move the seat position sensor from the rail of the OEM seat to the rail of the new seat.
Old 12-14-2014, 11:51 PM   #15
WorkTL
WorkTL's Avatar
Thanks. I will definitely be one of your 1st customers once you produce a bypass for the 12+ Yaris.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
I NEED to Figure a Way to Get More Front Seat Leg Room msmitka General Yaris / Vitz Discussion 25 09-08-2010 08:29 PM
Steering wheel emblem FlintMica08 Cosmetic Modifications (Exterior/Interior) 8 12-31-2009 06:32 PM
WTB: Leather Steering Wheel, RS Seats, RS Spoiler keisuke_z Willing to Buy by private party 1 03-13-2009 07:20 PM
rattles (front of steering wheel) wushumasterku DIY / Maintenance / Service 37 09-11-2007 12:24 AM
