Enthusiast
Drives: 07 Yaris HB 1.3 (EU) Join Date: Nov 2014
Fuel consuption rocketed after oil change
2 weeks ago I took my 07 Avensis (1.8 engine 147hp) for an oil change. They put in castrol 5w40 fully synthetic.
But I noticed the fuel consuption rocketed. Highway; avg. consumption was 5,8-6,2 while now after the change its between 8-8,4lt/km City driving; avg. was 7,1-7,4 now is 10,1-10,3 lt/km Any ideas? I havent changed my driving pace, I always shift at around 2.500rpm. I wont be receiving my OBD2 adapter till January, so any suggestions as to what it may be are welcome. Note that the tires have normal pressure levels. Thanks. Note: I dont know if the thread has to go to off topic subforum etc. If theres a place for it to be moved, please do so. Heres my avensis for those who are wondering what the heck it is (im talking about you 'muricans )![]() ![]() ![]() Sent from my awesome Xperia Z1 C6903 using Tapatalk.
Cheers, George. |
Have you checked what oil is needed for your car? Usually written on the oil cap. (Not sure if that's the case in EU)
But my guess that you should use 5w30 instead. |
Enthusiast
I always used fully synthetic 5w40
I tried once semi synthetic but had the same problem as now. When I replaced semi synthetic with fully synthetic this problem went on for about a month then consumption went back to normal Sent from my awesome Xperia Z1 C6903 using Tapatalk.
Cheers, George. |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Check the oil fill level?
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
Enthusiast
You mean with the dipstick? If yes then its at the normal level
Cheers, George. |
SMH,
. Hopefully we will never again have to hear a POTUS so lacking re proper elocution. As much as I can't stand Obama, Obama gets an A in this area (when he isn't trying to affect the accent/cadence/etc. most accepted by the audience of a given speech/presentation ...something he does with far greater competence than Hillary). Giving #43 (GWB) a passing grade in this area would be generous at best.
#7 | |
Enthusiast
Cheers, George. |
My bet is that your oil changer accidentally used a much more viscous oil than 5W40.
#9 | |
Enthusiast
Cheers, George. |
Enthusiast
Nope, oil is correct. Today the consumption went up to (avg. 14-14,5lt/km)
Cheers, George. |
#11 | |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Oct 2012
May I ask? What is POTUS?
Roy |
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
also wondering what this means Have you noticed any loss of power? (my suggestion would have been tire pressure (as this had applied to me) if you wouldn't have mentioned it)
I drive, therefore I am. |
Enthusiast
I did actually. Everythings okay with tire pressure etc. Im still waiting for my obd scanner tho.... Merry Christmas
POTUS means president of the united states. Sent from my awesome Xperia Z1 C6903 using Tapatalk.
Cheers, George. |
Embracing Curves
I would check the injectors next, but that might be a kind of a mess I would not do before checking the long term fuel trim.
I'm also interested how the o2 values vary.
Sorry
. It's the acronym (in English...or perhaps more accurately in American English) for President of the United States. Other examples of acronyms (in English) would be NATO for North Atlantic Treaty Organization and SCOTUS for Supreme Court of the United States.
^^^^ Sorry. I saw post #12 and replied to it without scrolling down, thinking Vivalaflam had posted post #12 because I used it in the reply to him. It is too early
#18 | |
Enthusiast
Cheers, George. |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 08:43 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| Oil filter seeping oil from seal : Should I change it ? | Hershey | DIY / Maintenance / Service | 33 | 11-14-2012 04:25 PM |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 09:22 PM |
