![]() Drives: 2003 toyota echo 1.5l manual Join Date: Oct 2012
hi guys im starting a new build on my echo. i got a td03 turbo for free from school and that just gave me enough motivation to actually think about boosting the little car. as of now i have the turbo and a small intercooler off of a mazda millenia. currentley what i have done to the car is
echo rs leather steering wheel echo rs aluminum rims echo rs seats removed spare tire power steering delete a/c delete changed clutch (used a toyota celica clutch and pressure plate)$80 off ebay lol muffler delete turbo gauge 4in1 aem fi/c and now a list of things still to do install aem fi/c custom turbo manifold oil lines / coolant lines intake piping tires (planning on hankook optimo 4s) rebuild turbo i dont expect to get much hp from this tiny turbo (looks like a 0.3 ar) maybe 150ish but i do plan on getting a bigger turbo in the distant future. ![]() ![]() ![]() ![]()
![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
Looks good, keep us posted :)
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin |
looks like the turbo seals are shot. Hope you're doing a rebuild on it first.
is there any way of checking the seals without installing it? because i know the volvo that it was on had a bad pcv.
You can pressure test it off the car. I would test it to at least 80 psi. The easiest way to do so is with air. Plug one of the oil ports and charge the other. I built a rig for pressure testing things that has a quick disconnect air fitting, then a ball valve, then a 3 way T with a pressure gauge on the second leg and the connection to what I want to test on the third. attach it to the device, connect it to the air compressor and charge it to the desired pressure, then close the ball valve and watch the gauge. If it starts to drop, then you have a leak.
thanks for the tip. i hooked it up to a little 12v tire pump and i started hearing a hissing noise at around 5psi:/ so i guess i got to rebuild it. i might try an ebay rebuild kit.
Was the air coming out of one of the turbines? Also is there any shaft play?
yes the air was coming out of the compressor side and there is a bit of shaft play
It's definitely something to put on the 'to do' list then.
well after driving around and hearing a clunk on every bump i found out that my rr shock was blown :/ good thing i have a parts car.
That sucks. Luckily they're really easy to change.
yeah real easy. the last echo i did it on took 5 min and i didn't even need to jack the car up
Any updates?
getting the replacement shock from the parts car but otherwise nothing new. this will probably be a slow build since im still in high school and its not my no.1 priority but i will still post updates if i get any new parts.
here is a little update on the turbo.
got the turbine housing off with a hammer and chisel ![]() compressor wheel came off with ease ![]() turbine side bearing has score marks on the outside O.o ![]() could not get this circlip off so i stoped here for now
Needle nose pliers won't fit?
Sent from my iPod Touch |
ok i got the little circlip out and got the the rest of the turbo apart.
That is one cooked turbo. Hopefully you can clean it all up and rebuild it.
| Tags |
| custom, echo, td03, turbo |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 09:14 PM |
| Want to build costom turbo kit. Need advice from boosted guys! | pimp my yaris | Forced Induction Forum | 639 | 09-28-2013 12:26 PM |
| XB HKS turbo kit, on an echo | taKuto | Forced Induction Forum | 28 | 01-14-2013 10:39 PM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-10-2012 12:35 AM |
| build Log : take 2... | FcukThis | In Car Entertainment + Electronics (audio / video / alarm) | 62 | 09-15-2010 04:00 AM |
