![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2015
ABS on 09' Hatchback
Hello, everyone, I'm new to the forum and have been looking for some answers regarding the abs system on the 2009 hatchback. The front left wire was "ripped" from the connection due to ice build up. The shroud in the left front wheel was ripped out this past fall as I did not replace in time. Due to my negligence ice built on the wire and the wire was ripped from the connection above the tire on the inner fender. The wiring is blue and white on the abs, however the wiring harness has a green and red. I'm not sure of the correct wiring, I need to know if it is connection sensitive and which wire to which. The parts are all OEM. Any help would be greatly appreciated thank you!
The wiring diagrams just show red and green for the front left and pink and violet for the front right. But, looking at pictures of sensor, it looks like Pin 1 is white and Pin 2 is green, so that would mean white to green and green to red and white to violet and green to pink.
| Wanted: 2007-08 Yaris S instrument cluster (w/tach w/o ABS) for 2007 Yaris hatchback | AndyW | Willing to Buy by private party | 6 | 12-07-2014 09:53 PM |
| 06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 03:14 PM |
| 3 Door Hatchback Questions | Dorkinheimer | General Yaris / Vitz Discussion | 12 | 01-16-2012 06:30 PM |
| What's with ABS? | jgag123 | Canada | 9 | 01-01-2009 07:04 PM |
| Hatchback with abs ? | "G" | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 02-20-2007 10:17 PM |
