Old 02-21-2015, 08:10 AM   #1
Yarisaur
Drives: 07 Yaris
Exhaust bolt size?
I need to know what Thread/size bolt fits the axle back portion of our cars, I no longer have the spring bolts and need two bolts that fit! dumb question but hope someone can help!!
Yarisaur is offline   Reply With Quote
Old 02-21-2015, 09:55 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Get the spring bolts kit from Rockauto. They are like 6$ or so.
Old 02-21-2015, 12:51 PM   #3
Are you looking to temporarily bolt together until you can get new spring bolts? If not, and what you are doing is permanent, forget it. The gasket will not function properly without spring bolts.
Old 02-21-2015, 05:00 PM   #4
Yarisaur
Drives: 07 Yaris
no looking to use regular bolts to attach my Dc Sport axle back it has no gasket, which is currently off the car. had the spring bolts but they were causing an awful rattle that was driving me mad, so I took everything off until I find a solution. The noise was from the bolts because when it would rattle I could put my hands over the spring bolts and it would stop.
Old 02-21-2015, 05:54 PM   #5
Some of the aftermarket exhausts don't work well with the short thread section of the OEM bolts. The OEM ones are: M10 1.25 pitch. The RockAuto ones mentioned above are threaded for the entire length of the bolt.
Old 02-22-2015, 04:49 AM   #6
Yarisaur
Drives: 07 Yaris
Ahh okay! Thank you, Thats what I needed to know! Guess Ill order those ones from Rockauto.
Old 02-26-2015, 02:31 AM   #7
Yarisaur
Drives: 07 Yaris
Got the bolts from rock auto, and there not threaded all the way on the bolt, just the tip like the factory ones so we will see if these work if not I will need to get new 10m 1.25 bolts to use with these springs
Old 02-26-2015, 07:05 AM   #8
IllusionX
Make sure you get the stainless steel ones from Home Depot.
Old 02-26-2015, 06:35 PM   #9
Ah. They must have changed suppliers. I have two sets sitting here that are both the full threaded ones.
Old 03-25-2015, 10:25 PM   #10
IllusionX
That's weird. I am shopping for new bolts kit and gaskets for mine, and according to RockAuto, they are fully threaded with a sleeve to cover part of it.
Bolt Pattern Size and Offset for the Stock Wheels fmicle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 08-12-2009 03:35 PM
Size of exhaust hanger?? AlainMikli Performance Modifications 3 07-05-2009 05:07 PM
head bolt socket. What size? beemer dave DIY / Maintenance / Service 3 06-02-2009 04:15 PM
GReddy prototype = Free Exhaust! Chris_Lum California 30 02-27-2007 10:13 PM
Fujitsubo Exhaust!! MC-BPT Sponsors Classifieds Area 17 11-16-2006 10:36 AM
