Old 10-03-2014, 02:16 PM   #199
matti
Drives: 2017 Yaris L (5sp manual)
Originally Posted by Jlively View Post
Tired of that pesky Maint req light?
Turn it off yourself.
step 1: put your trip odometer to trip A
Step 2: turn the car off.
Step 3: using your left hand on the key and your right hand holding down the button to reset the odometer in, turn the key to the on position and keeping holding down the button. It will do a few cirlces and show 2-4 flat lines then your mileage will come back and viola the maint req light is gone. Reset the trip odometer to normal, trip a, trip b w/e you use. Now your done, have a cookie!
lol, not sure that's much of a secret!
matti is offline   Reply With Quote
Old 10-03-2014, 07:33 PM   #200
Jlively
Mr J.
Drives: 2009 yaris 5 dr HB
Send a message via AIM to Jlively
Yea well I didnt know about it until recently and I havent seen it.posted on here anywhere. And was told it only worked for yaris and scion xb, xa so I thought I'd share it secret or not
Jlively is offline   Reply With Quote
Old 10-08-2014, 03:55 AM   #201
nookandcrannycar
Just noticed this 10/7/14.....The 'bin/holder/whatever you want to call it' at the very back of the center floor console cradles a 2 liter bottle of Kroger Diet Citrus Drop...quite snugly (wouldn't worry that it would fall out).
^^^^^ Re my 2014 Yaris
Last edited by nookandcrannycar; 10-08-2014 at 10:29 PM. Reason: added re my 2014 Yaris
Old 10-08-2014, 10:03 AM   #202
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
Make radiator fan run while the car is off
To do this, turn the A/C on just like you're using it when driving.
(Blower fan on. Temperature knob in the blue zone)
And then, turn the key half-way between ACC and ON position.
(Just so that the instrument cluster doesn't power up)
Mittelklasse is offline   Reply With Quote
Old 11-15-2014, 02:55 PM   #203
Mittelklasse
Problem, officer?
Separate EQ settings for CD and radio
I came across this one by accident. Since I had my battery disconnected, the settings on my stock stereo reset back to default values.
So, while I was adjusting the bass and treble again, I found out that they allow separate settings for CD and radio mode! Pretty clever eh.
Old 03-09-2015, 04:21 PM   #204
lenzomaru
lenzomaru's Avatar
Drives: 07' Yaris S & 89' Mazda 323 LX
in the 1.3 engine you roll backward if you let go the gas on a small incline
"Cooler than the other side of the pillow"
lenzomaru is offline   Reply With Quote
Old 03-09-2015, 04:25 PM   #205
lenzomaru
lenzomaru's Avatar
Even after you switch off the car completely The power windows still work for a good minute, if you open any door however, it stops working.
Old 03-11-2015, 08:14 PM   #206
sheekeebut
Minimalist
Drives: 07 silver sedan
My kid buried pennies, peanuts and rocks under the bench seat, probably through the tiny opening for the seat belt buckles. For a year, I couldn't figure out the rolly jingly noises in the back when I took a turn. He kept that a secret until I lifted the bench cushion for a track day.
sheekeebut is offline   Reply With Quote
Old 03-14-2015, 01:47 AM   #207
Idahotom
Drives: 2008 5 sp. LB
Originally Posted by barebonedvitz View Post
the brace underneath the rear seats in the LB act as a.. well... center brace... so there's no real need to buy that under-chassis brace at all...
figured this out when i took off my seats..
I yanked my rear seat right away, and eventually bought a underneath brace. So, did you put your seat back in? I use all that space too often, plus I save a few pounds, even though it's also a little noisier I guess.
Idahotom is offline   Reply With Quote
Interesting Info on the Yaris from AU mikeukrainetz General Yaris / Vitz Discussion 3 11-24-2006 10:18 PM
