![]() Drives: 08 Yaris Sedan Join Date: Jun 2014
Looking for a steel rim!
In the western KY/Southern IN area. Looking for a 15" Steel rim that will fit my 08 Yaris Sedan. do not need the TPMS sensor just a rim.
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
Did you try a scrap yard, oops, Auto recycler?
There are a bunch around here with Yaris parts. Currently being advertised on Craig's list. Norton |
I've tried one so far and they said 125 for a steel rim and I feel thats pretty steep for a steel rim. Might look around in nearby towns and see what I can find. I also need to find a Hood for my car as well but can't find a yaris sedan in any scrap yards :P
A new wheel would be less. I bought a used wheel/tire (15") and four hub caps last fall for
$25. Too bad I don't have plans to Indy until the fall. Check Craig's list. Good luck. Norton |
2ZR swap. DO IT! Ask how!
Try car-part.com to see what salvage yards have in stock. That's about the best resource for used parts that I've found. The Yaris often has too much resale value to go into the self-serve scrap yards.
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
RockAuto.com has a few for only $57 each. They're replicas though, if you're okay with that.
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
really? I could only find the aluminum rims for 125. will have to look harder
On a side note I need a Hood for my sedan as well. Hoping I can find one at a scrap yard |
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 09:44 AM |
| I NEED A 15" STEEL RIM AND OEM TIRE | robkay | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 12-18-2009 10:57 AM |
| Need a 15" steel rim | aephilli | Willing to Buy by private party | 0 | 11-20-2009 10:06 AM |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 06:42 PM |
| Rim sizing - what size to get for OE equivalent? | jay | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 11-20-2006 03:25 PM |
